i got errors when i try to get certificates by the following command:
/opt/letsencrypt/letsencrypt-auto --config /etc/letsencrypt/cli.ini --debug certonly
i got the following output
Checking for new version…
Creating virtual environment…
Installing Python packages…
Requesting root privileges to run letsencrypt…
/root/.local/share/letsencrypt/bin/letsencrypt --no-self-upgrade --config /etc/letsencrypt/cli.ini --debug --dry-run certonly
File “/root/.local/share/letsencrypt/bin/letsencrypt”, line 5, in
from pkg_resources import load_entry_point
File “/root/.local/share/letsencrypt/lib/python2.6/site-packages/pkg_resources.py”, line 3007, in
working_set.require(requires)
File “/root/.local/share/letsencrypt/lib/python2.6/site-packages/pkg_resources.py”, line 728, in require
needed = self.resolve(parse_requirements(requirements))
File “/root/.local/share/letsencrypt/lib/python2.6/site-packages/pkg_resources.py”, line 626, in resolve
raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: unittest2
in /etc/letsencrypt/cli.ini are the following options
rsa-key-size = 4096
plugin
authenticator = webroot
webroot
webroot-path = /home/httpd/html/name/
domains
domains = domain.tld, test.domain.tld
flags
renew is good for automation
renew-by-default
i have root acces on a server with a fresh installed centos 6.7 and for the installation of letsencrypt i followed the instruction of https://www.svennd.be/lets-encrypt-with-centos-6/
what can i do?
