My domain is: albadizayn.com
I ran this command: letsdebug.net / also i use CWP autossl button
letsdebut.net
ANotWorking
ERROR
albadizayn.com has an A (IPv4) record (80.93.209.81) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with albadizayn.com/80.93.209.81: Get "http://albadizayn.com/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://albadizayn.com/.well-known/acme-challenge/letsdebug-test (using initial IP 80.93.209.81)
@1ms: Dialing 80.93.209.81
@10000ms: Experienced error: context deadline exceeded
Autossl Log
DNS Redirection problem for albadizayn.com with www and without it
My web server is (include version): Apache/2.4.51 + nginx/1.20.2
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): cwp
or certbot-auto --version
if you're using Certbot): acme v3.0.2
I am having this problem with every domain on same server. So i thought it's a firewall problem. I've completely disabled firewall (CSF) nothing change. I allowed 0.0.0.0/0 all ports in out nothing changed.
I'm stuck.
