Let's Encrypt renewal simulation problem
Hello,
I obtained cert by using --standalone auth plugin while there was no any web server running, with this command:
sudo certbot certonly --standalone --domains example.com --rsa-key-size 2048 --must-staple --email admin@example.com --no-eff-email --agree-tos --preferred-challenges tls-sni
Everything went fine.
Now, I installed NGINX and want to renew cert by using --webroot. I edited /etc/letsencrypt/renewal/example.com.conf
file and added the following:
authenticator = webroot
webroot-path = /path/to/webroot
Then, I run sudo certbot renew --dry-run and I get the following error:
Attempting to renew cert (example.com) from /etc/letsencrypt/renewal/example.conf produced an unexpected error: Missing command line flag or config entry for this setting:
Select the webroot for example.com:
Choices: ['Enter a new webroot']
(You can set this with the --webroot-path flag). Skipping.
I expect this to work but it isn’t. What is wrong with this ?
OS: Ubuntu 16.04.3
Certbot: 0.17.0
Hi @blaja,
Could you please post the entire file /etc/letsencrypt/renewal/example.conf before the edit and after your edit?.
Cheers,
sahsanu
Hi @sahsanu,
Before edit:
version = 0.17.0
archive_dir = /etc/letsencrypt/archive/example.com
cert = /etc/letsencrypt/live/example.com/cert.pem
privkey = /etc/letsencrypt/live/example.com/privkey.pem
chain = /etc/letsencrypt/live/example.com/chain.pem
fullchain = /etc/letsencrypt/live/example.com/fullchain.pem
[renewalparams]
account = xxxxxxxxxxxxxxxxxxxxxxxxx
must_staple = True
authenticator = standalone
rsa_key_size = 2048
installer = None
pref_challs = tls-sni-01,
After edit:
version = 0.17.0
[renewalparams]
must_staple = True
#authenticator = standalone
rsa_key_size = 2048
installer = None
#pref_challs = tls-sni-01,
Hi @blaja,
Change it to this:
version = 0.17.0
[renewalparams]
rsa_key_size = 2048
installer = None
[[webroot_map]]
example.com = /path/to/example.com/webroot
If your certificate is currently covering more domains, like www.example.com, in section [[webroot_map]] you need to write a line for each of them pointing to the webroot used in your nginx conf.
[[webroot_map]]
www.example.com = /path/to/www.example.com/webroot
Also, it is a good idea to reload your nginx service once the renewal is being processed.
post_hook = service nginx reload
or
post_hook = systemctl reload nginx
or whatever your system uses to reload it.
Example with 2 domains (example.com and www.example.com) and reloading nginx using service once the cert is renewed:
version = 0.17.0
[renewalparams]
rsa_key_size = 2048
installer = None
[[webroot_map]]
Cheers,
sahsanu
