Let's encrypt problem during Nginx host configuration
Hello,
I'm using Nginx proxy manager add-on in Home assistant.
I would like to use Nginx in Docker container (debian 12) so I made the docker compose and I created my container without any problem.
When I would like to create my first Proxy Host, I have an "Internal error".
I have the following message in my log file:
[Express ] › :warning: warning Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-2" --agree-tos --authenticator webroot --email "MYMAIL" --preferred-challenges "dns,http" --domains "MYDOMAIN"
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Could you please help me to understand this message?
Thank you.
Hello @AURELB87, welcome to the Let's Encrypt community. :slightly_smiling_face:
You might find help from Home Assistant also has its own community forum here https://community.home-assistant.io/
Thank you for assisting us in helping YOU!
I'm afraid not with the info provided. Nginx Proxy Manager is notorious for not providing the relevant information from the Certbot output. Besides the questions from the questionnaire above, please also show the contents of the Certbot log file /tmp/letsencrypt-log/letsencrypt.log so we can see what's going on more clearly.
As I said, I'm currently using the Nginx addon on my homeassistant without any problem.
May be I have this message because I already set the proxy host in the addon... I already tried to delete the configuration in the addon but nothing change.
Here is the log file: logfile - Pastebin.com
That wasn't the whole log file.
But, based on the limited info you have provided my guess is that NPM is placing the challenge file in /data/letsencrypt-acme-challenge/.well-known/acme-challenge/ folder but the container running nginx doesn't have access to that folder.
Here is the slightly more helpful message from the log
Certbot failed to authenticate some domains (authenticator: webroot).
The Certificate Authority reported these problems:
Domain: (redacted)
Detail: (IP redacted): Invalid response from http://(redacted)/.well-known/acme-challenge/URqx0itUw4hRLupQV4Y2SGHJwDqkuUGP_3fsKYDOsig: 404
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from
