Let's Encrypt is not renewing
My domain is: cafe.cbtec.com
The operating system my web server runs on is (include version):windows server 2019
My hosting provider, if applicable, is: DartPoints
I have a site cafe.cbtec.com that is not updating the cert file. I have worked today trying to get the certificate updating again. I am not sure if I need to update my version of letsencrypt or if I need different servers. My server is a Windows 19 server and is a hosted VM. Certbot version is 6.0.18.0.
Thank you if you have time to point me in the right direction.
Hello @seattlebears, welcome to the Let's Encrypt community. :slightly_smiling_face:
Since you did not answer this question:
I am going to make an assumption that the HTTP-01 challenge (the most commonly used) of the Challenge Types - Let's Encrypt and it states
"The HTTP-01 challenge can only be done on port 80."
Best Practice - Keep Port 80 Open
Using the online tool Let's Debug yields these results https://letsdebug.net/cafe.cbtec.com/2032133
ANotWorking
ERROR
cafe.cbtec.com has an A (IPv4) record (69.2.51.140) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with cafe.cbtec.com/69.2.51.140: Get "http://cafe.cbtec.com/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://cafe.cbtec.com/.well-known/acme-challenge/letsdebug-test (using initial IP 69.2.51.140)
@0ms: Dialing 69.2.51.140
@10000ms: Experienced error: context deadline exceeded
IssueFromLetsEncrypt
ERROR
A test authorization for cafe.cbtec.com to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
69.2.51.140: Fetching https://cafe.cbtec.com/.well-known/acme-challenge/SKZ40hWZmuT3Y8RDkH9pspP9BkZfeHOIunFFZJqwqnM: received disallowed redirect status code
Using nmap from my Oregon, USA locations I see
$ nmap -Pn -p80,443 cafe.cbtec.com
Starting Nmap 7.80 ( https://nmap.org ) at 2024-06-15 01:04 UTC
Nmap scan report for cafe.cbtec.com (69.2.51.140)
Host is up (0.074s latency).
rDNS record for 69.2.51.140: 140.51.venyu.com
PORT    STATE SERVICE
80/tcp  open  http
443/tcp open  https
Nmap done: 1 IP address (1 host up) scanned in 0.57 seconds
I believe there is geo blocking
http://www.site24x7.com/tools/public/t/results-1718413205834.html
Edit: and here too Permanent link to this check report
Please read these:
6.0.18.0 looks like https://certifytheweb.com/ version
@webprofusion your client I guess
Looks like it to me too.
Not certbot @seattlebears
Version 6.0.18 Release Notes SHA256
So it looks like you've been managing to get your certs up until recently, this just looks like geoblocking. I can't access your site from australia but it works from other locations, so you're probably blocking one of the other countries Let's Encrypt uses.
Remove the geoblocking from your firewall and allow incoming http (TP port 80) or allow all http /.well-known/acme-challenge requests if you have a sophisticated enough firewall to specifically allow that.
Your web server is IIS, not apache.
