Let's Encrypt failing with Detail: Incorrect validation certificate for TLS-SNI-01 challenge
#1
My domain is: www.carespanhealth.com
I ran this command: certbot --apache certonly
Domain: www.carespanhealth.com
Detail: Incorrect validation certificate for TLS-SNI-01 challenge.
Requested
2033753c2bcba039c876a87a716dc063.7d91918a9ca94e4e0e85a36513ad7bfa.acme.invalid
from 66.161.32.89:443. Received certificate containing
carespanhealth.com, www.carespanhealth.com
My operating system is (include version): CENTOS 7
I have a currently active wildcard cert that expires in 28 days. Is this the cause of the error?
Because I have multiple vhosts conf files, I generate the certs then manually add them to my Apache config. I have done this on another server but this server seems to not like me.
I have disabled https on this site both here and in the .htaccess file. Same result. Ideas?
Trouble setting up Apache2 with CertBot
#2
a) From the point of view of all the clients out there on the internet you don’t have a wildcard certificate: just a GoDaddy cert for carespanhealth.com and www.carespanhealth.com. Not *.carespanhealth.com.
b) Do you use some kind of reverse proxy such as a CDN from GoDaddy? Because certbot --apache uses the ‘local’ Apache to try and verify the tls-sni-01 challenge, it can’t be ran on a different server.
#3
I guess you’re right. I only have the www cert. And no. I use a virtual host that I control at the AT&T data center. By godaddy DNS parameters are exactly the same is the ones for my certs that work (leadinar.com). For that site. I have to disable port 443 in my vhosts file. I tried the same on carespanhealth but get the same response. These two sites are on different VMs, but they are configured similarly.
#4
Disabling port 443 shouldn’t be necessary. The way the tls-sni-01 (which is used when using --apache for the authentication part) challenge works is generating a temporary self-signed certificate (with something like your 2033753c2bcba039c876a87a716dc063.7d91918a9ca94e4e0e85a36513ad7bfa.acme.invalid as the common name) and a temporary vhost configuration file pointing to the aforementioned self-signed certificate. Next it reloads your Apache, so the Let’s Encrypt servers can find it.
Problems can arise with the tls-sni-01 challenge when a) DNS points to another server than the server certbot is running on (which isn’t the case you just said) or b) something is wrong/‘messing up’ your Apache. Some users had a non-default configuration of their Apache which didn’t properly ‘pick up’ the Let’s Encrypt temporary configuration file. You could run certbot with the extra -v switch so it outputs more verbose information. Even -vv is possible, but gives you a lot of junk too.
#5
Thanks. I’ll
Give that a shot. Probably an apache config thing.
#6
This is getting frustrating. Nothing I do seems to help. I get the same error. The site is currently running with a cert that expires in 14 days. Do I need to disable that first? What kinds of things in the Apache config can cause a problem if that is it? I am stuck.
#7
Never mind. I used webroot and that worked.
#8
