erronak
November 23, 2018, 11:24am
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: smud8165.info
I ran this command: “./letsencrypt-auto --apache -d smud8165.info -d www.smud8165.info”
Congratulations! You have successfully enabled https://smud8165.info and
https://www.smud8165.info
https://www.ssllabs.com/ssltest/analyze.html?d=smud8165.info
https://www.ssllabs.com/ssltest/analyze.html?d=www.smud8165.info
My web server is (include version): Apache 2.2
The operating system my web server runs on is (include version): Cent OS -6
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No, I don’t have control panel
Hi @erronak
you have created one certificate with two domain names:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:smud8165.info&lu=cert_search
This is good. But you use a self signed certificate.
1.
1.
E=root@smud8165.info, CN=smud8165.info, OU=SomeOrganizationalUnit, O=SomeOrganization, L=SomeCity, S=SomeState, C=-- (120)
23.11.2018
23.11.2019
Keyalgorithm
RSA encryption (2048 bit)
Signatur:
SHA256 With RSA-Encryption
Serial Number:
31BD
Thumbprint:
672BD65FEB1B1A3B9E2D486FED26ED8804AE4DB5
OCSP - Url:
OCSP - must staple:
no
Certificate Transparency:
no
UntrustedRoot: A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider.
First try: Reload your Apache. If this doesn't help, check your certificates with
./letsencrypt-auto certificates
then your configuration to find your correct vHost.
erronak
November 23, 2018, 11:43am
3
I restarted my services with following commands but didn’t get result.
service named restart;
service httpd restart;
so what I have to do now ?
I am open to show you my configuration files.
Could you please check if your DNS server is configtured correctly?
I can’t access your website right now and because the DNS server is not responding…
By the way, could you please share us a screenshot of the issue?
Thank you
erronak
November 27, 2018, 3:38pm
5
Hello ,
I tried this link and it is working for me.
system
Closed
December 27, 2018, 3:38pm
6
