Lets Encrypt connection error during tls-sni-01
dustindoloff.com
./certbot-auto --debug
Requesting root privileges to run certbot...
  /home/ec2-user/.local/share/letsencrypt/bin/letsencrypt --debug
1: ****.com
2: www.****.com
3: ****.co
4: www.****.co
5: dustindoloff.com
6: **.dustindoloff.com
7: test.dustindoloff.com
blank to select all options shown (Enter 'c' to cancel): 5
tls-sni-01 challenge for dustindoloff.com
Exiting abnormally:
  File "/home/ec2-user/.local/share/letsencrypt/bin/letsencrypt", line 11, in <module>
    sys.exit(main())
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/main.py", line 743, in main
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/main.py", line 598, in run
    certname, lineage)
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/main.py", line 82, in _get_and_save_cert
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/client.py", line 356, in obtain_and_enroll_certificate
    certr, chain, key, _ = self.obtain_certificate(domains)
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/client.py", line 317, in obtain_certificate
    self.config.allow_subset_of_names)
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 81, in get_authorizations
    self._respond(resp, best_effort)
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 138, in _respond
    self._poll_challenges(chall_update, best_effort)
  File "/home/ec2-user/.local/share/letsencrypt/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 202, in _poll_challenges
    raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. dustindoloff.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Error getting validation data
   Domain: dustindoloff.com
   Type:   connection
   Detail: Error getting validation data
Server version: Apache/2.4.25 (Amazon)
Server built:   Jan 19 2017 16:55:49
Amazon Linux 2017
Linux ip-XXX-XXX-XXX-XXX 3.14.48-33.39.amzn1.x86_64 #1 SMP Tue Jul 14 23:43:07 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
AWS EC2
no
I have uploaded the logs from here
/var/log/letsencrypt/letsencrypt.log
What I've done to troubleshoot:
  • Try an individual domain instead of all at once
  • Verify the security group for the EC2 instance is correct and allows incoming requests on port 443 from all IP addresses
  • Verify the IP address in the logs matches the public IP address of the domain
As there is no current response on port 443…
You could try:
./certbot–auto --apache --debug
or maybe use webroot parameter
I ended up manually configuring my httpd.conf, which I was hoping to avoid by using the tool, but now everything is setup, albeit more manually than I was hoping for. I never did figure out why it couldn't verify it with apache, but switched to --standalone and used certonly to get the cert
For anyone out there reading this to debug for themselves
To get the register the domain with certbot I did:
$ sudo ./certbot-auto --debug certonly
To verify the domain and actually get the cert:
$ sudo ./certbot-auto --debug --standalone --installer apache
I found that I also had issues where my manual configuration of the certs would cause apache to fail to start, so I would have to comment out the SSLCertificateFile and SSLCertificateKeyFile lines in order to get certbot far enough forward to actually download the cert.
