My domain is: cloudimagewall.xyz
I ran this command: N/A
My web server is (include version): Ubuntu 16.04
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: DigitalOcean
I'm following this tutorial using Docker Nginx Letsencrypt:
But i got the error when Requesting a certificate:
Domain: cloudimagewall.xyz
Type: connection
Detail: Fetching http://cloudimagewall.xyz/.well-known/acme-challenge/-XVii9vyU_jR9xOgxhcate_e176tHZcYKCfIZqG2tXg: Connection refused
I test letsdebug.net website and i see this error:
ANotWorking
ERROR
cloudimagewall.xyz has an A (IPv4) record (139.59.240.138) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "http://cloudimagewall.xyz/.well-known/acme-challenge/letsdebug-test": dial tcp 139.59.240.138:80: connect: connection refused
Trace:
@0ms: Making a request to http://cloudimagewall.xyz/.well-known/acme-challenge/letsdebug-test (using initial IP 139.59.240.138)
@0ms: Dialing 139.59.240.138
@226ms: Experienced error: dial tcp 139.59.240.138:80: connect: connection refused
This is my ubuntu server firewall status
This is my nginx config:
listen 80;
server_name cloudimagewall.xyz www.cloudimagewall.xyz;
root /var/www/certbot;
listen 443 ssl;
server_name cloudimagewall.xyz;
# SSL configuration
ssl_certificate /etc/letsencrypt/live/cloudimagewall.xyz/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/cloudimagewall.xyz/privkey.pem;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
client_max_body_size 30M;
proxy_set_header Host $http_host;
proxy_pass http://node-app:3000;
# proxy_redirect off;
# enable WebSockets
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
I'm stucking in this for hours but cannot solve it, hope someone can help me.
rg305
August 25, 2021, 3:09am
2
You're missing the www in the secure vhost.
rg305
August 25, 2021, 3:12am
3
All four connections are being refused:
http://www.cloudimagewall.xyz
https://cloudimagewall.xyz
https://www.cloudimagewall.xyz
Are you sure you are at the right IP address?
From the server, please show the output of:
curl -4 ifconfig.co
the output is: 139.59.240.138
rg305
August 25, 2021, 3:20am
5
Well that does match DNS:
Address: 139.59.240.138
Aliases: www.cloudimagewall.xyz
Is there a NAT/PAT device involved?
Sorry I dont understand what NAT/PAT mean so maybe my answer is no
rg305
August 25, 2021, 3:24am
7
Is there a router involved?
If so, does it do any address, or port, translation?
rg305
August 25, 2021, 3:25am
8
ducchuy:
using Docker
Ok, where you ever able to reach the HTTP site?
You will need a functional HTTP site in order to secure it (via HTTP authentication method).
Uhm right now all I know is all my docker container running but my nginx container is down
My nginx container keep showing this error:
open() "/etc/letsencrypt/options-ssl-nginx.conf" failed (2: No such file or directory) in /etc/nginx/conf.d/default.conf:23
nginx: [emerg] open() "/etc/letsencrypt/options-ssl-nginx.conf" failed (2: No such file or directory) in /etc/nginx/conf.d/default.conf:23
Ok, where you ever able to reach the HTTP site? yes
When i dont using letsencrypt and it working fine
rg305
August 25, 2021, 3:30am
11
I would start by editing out that part in this file:
[just to get nginx going again]
In my nginx logs it showing this:
cannot load certificate "/etc/letsencrypt/live/cloudimagewall.xyz/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/cloudimagewall.xyz/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
because when i request certificate certbox failed to authenticate:
Type: connection
Detail: Fetching http://cloudimagewall.xyz/.well-known/acme-challenge/C0C2rqlciikQL7--qKVtYLnv4HqH6A2dK117bthJhq4: Connection refused
rg305
August 25, 2021, 3:38am
13
Can you disable that whole server section of the file?
Oh i just retry to request certificate when all my server container is running and it success
But my url is unsecured for some reason
rg305
August 25, 2021, 3:43am
16
It isn't serving the correct certificate.
the url auto add a dash to https and said it unsecure
Now my nginx logs showing this new error:
[error] 15#15: *22 open() "/var/www/certbot/.well-known/acme-challenge/spaJ_9L6kICDfGdO3xJSkluqglyXMwhsySeYAI4ERSw" failed (2: No such file or directory), client: 18.236.228.243, server: cloudimagewall.xyz, request: "GET /.well-known/acme-challenge/spaJ_9L6kICDfGdO3xJSkluqglyXMwhsySeYAI4ERSw HTTP/1.1", host: "cloudimagewall.xyz"
rg305
August 25, 2021, 3:46am
18
Actually it is using a staging certificate.
Not a real production certificate:
See: SSL Server Test: cloudimagewall.xyz (Powered by Qualys SSL Labs)
Ah you're right I almost forgot the setting to real certificate
rg305
August 25, 2021, 3:47am
20
And thank you for using the staging environment while testing
