Lestsencrypt cetifricate is not valid
So you don't have a working port 80 configuration.
Please start with some basics:
Then create one. A correct port 80 configuration with your domain name as vHost is a prerequisite. If you have an own web server, it's your job to create such a correct vHost.
And you should be able to modify your existing config so the port 443 todomaster.co vHost uses the correct certificate, not the self signed.
There is a redirect http + non-www to https + www, but there is no www vHost. So the standard vHost answers with the wrong certificate.
Looks like you have manually created a lot of bugs. Undo these.
I am on aws
and I used https://mycuteblog.com/aws-lets-encrypt/ this guide
please guide me the steps. if anything is wrong.
Can you show the contents of the following files:
  • /etc/httpd/conf.d/ssl.conf
  • /etc/httpd/conf/httpd.conf
    # When we also provide SSL we have to listen to the
    # the HTTPS port in addition.
    Listen 443 https
    ##  SSL Global Context
    ##  All SSL configuration in this context applies both to
    ##  the main server and all SSL-enabled virtual hosts.
    #   Pass Phrase Dialog:
    #   Configure the pass phrase gathering process.
    #   The filtering dialog program (`builtin' is a internal
    #   terminal dialog) has to provide the pass phrase on stdout.
    SSLPassPhraseDialog exec:/usr/libexec/httpd-ssl-pass-dialog
    #   Inter-Process Session Cache:
    #   Configure the SSL Session Cache: First the mechanism
    #   to use and second the expiring timeout (in seconds).
    SSLSessionCache         shmcb:/run/httpd/sslcache(512000)
    SSLSessionCacheTimeout  300
    #   Pseudo Random Number Generator (PRNG):
    #   Configure one or more sources to seed the PRNG of the
    #   SSL library. The seed data should be of good random quality.
    #   WARNING! On some platforms /dev/random blocks if not enough entropy
    #   is available. This means you then cannot use the /dev/random device
    #   because it would lead to very long connection times (as long as
    #   it requires to make more entropy available). But usually those
    #   platforms additionally provide a /dev/urandom device which doesn't
    #   block. So, if available, use this one instead. Read the mod_ssl User
    #   Manual for more details.
    SSLRandomSeed startup file:/dev/urandom  256
    SSLRandomSeed connect builtin
    #SSLRandomSeed startup file:/dev/random  512
    #SSLRandomSeed connect file:/dev/random  512
    #SSLRandomSeed connect file:/dev/urandom 512
    # Use "SSLCryptoDevice" to enable any supported hardware
    # accelerators. Use "openssl engine -v" to list supported
    # engine names.  NOTE: If you enable an accelerator and the
    # server does not start, consult the error logs and ensure
    # your accelerator is functioning properly.
    SSLCryptoDevice builtin
    #SSLCryptoDevice ubsec
    ## SSL Virtual Host Context
    <VirtualHost _default_:443>
    # General setup for the virtual host, inherited from global configuration
    #DocumentRoot "/var/www/html"
    #ServerName www.example.com:443
    # Use separate log files for the SSL virtual host; note that LogLevel
    # is not inherited from httpd.conf.
    ErrorLog logs/ssl_error_log
    TransferLog logs/ssl_access_log
    LogLevel warn
    #   SSL Engine Switch:
    #   Enable/Disable SSL for this virtual host.
    SSLEngine on
    #   SSL Protocol support:
    # List the enable protocol levels with which clients will be able to
    # connect.  Disable SSLv2 access by default:
    SSLProtocol all -SSLv3
    #   SSL Cipher Suite:
    #   List the ciphers that the client is permitted to negotiate.
    #   See the mod_ssl documentation for a complete list.
    SSLCipherSuite HIGH:MEDIUM:!aNULL:!MD5:!SEED:!IDEA
    #   Speed-optimized SSL Cipher configuration:
    #   If speed is your main concern (on busy HTTPS servers e.g.),
    #   you might want to force clients to specific, performance
    #   optimized ciphers. In this case, prepend those ciphers
    #   to the SSLCipherSuite list, and enable SSLHonorCipherOrder.
    #   Caveat: by giving precedence to RC4-SHA and AES128-SHA
    #   (as in the example below), most connections will no longer
    #   have perfect forward secrecy - if the server's key is
    #   compromised, captures of past or future traffic must be
    #   considered compromised, too.
    #SSLCipherSuite RC4-SHA:AES128-SHA:HIGH:MEDIUM:!aNULL:!MD5
    #SSLHonorCipherOrder on
    #   Server Certificate:
    # Point SSLCertificateFile at a PEM encoded certificate.  If
    # the certificate is encrypted, then you will be prompted for a
    # pass phrase.  Note that a kill -HUP will prompt again.  A new
    # certificate can be generated using the genkey(1) command.
    SSLCertificateFile /etc/pki/tls/certs/localhost.crt
    #   Server Private Key:
    #   If the key is not combined with the certificate, use this
    #   directive to point at the key file.  Keep in mind that if
    #   you've both a RSA and a DSA private key you can configure
    #   both in parallel (to also allow the use of DSA ciphers, etc.)
    SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
    #   Server Certificate Chain:
    #   Point SSLCertificateChainFile at a file containing the
    #   concatenation of PEM encoded CA certificates which form the
    #   certificate chain for the server certificate. Alternatively
    #   the referenced file can be the same as SSLCertificateFile
    #   when the CA certificates are directly appended to the server
    #   certificate for convinience.
    #SSLCertificateChainFile /etc/pki/tls/certs/server-chain.crt
    #   Certificate Authority (CA):
    #   Set the CA certificate verification path where to find CA
    #   certificates for client authentication or alternatively one
    #   huge file containing all of them (file must be PEM encoded)
    #SSLCACertificateFile /etc/pki/tls/certs/ca-bundle.crt
    #   Client Authentication (Type):
    #   Client certificate verification type and depth.  Types are
    #   none, optional, require and optional_no_ca.  Depth is a
    #   number which specifies how deeply to verify the certificate
    #   issuer chain before deciding the certificate is not valid.
    #SSLVerifyClient require
    #SSLVerifyDepth  10
    #   Access Control:
    #   With SSLRequire you can do per-directory access control based
    #   on arbitrary complex boolean expressions containing server
    #   variable checks and other lookup directives.  The syntax is a
    #   mixture between C and Perl.  See the mod_ssl documentation
    #   for more details.
    #<Location />
    #SSLRequire (    %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
    #            and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \
    #            and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \
    #            and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
    #            and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20       ) \
    #           or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/
    #</Location>
    #   SSL Engine Options:
    #   Set various options for the SSL engine.
    #   o FakeBasicAuth:
    #     Translate the client X.509 into a Basic Authorisation.  This means that
    #     the standard Auth/DBMAuth methods can be used for access control.  The
    #     user name is the `one line' version of the client's X.509 certificate.
    #     Note that no password is obtained from the user. Every entry in the user
    #     file needs this password: `xxj31ZMTZzkVA'.
    #   o ExportCertData:
    #     This exports two additional environment variables: SSL_CLIENT_CERT and
    #     SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
    #     server (always existing) and the client (only existing when client
    #     authentication is used). This can be used to import the certificates
    #     into CGI scripts.
    #   o StdEnvVars:
    #     This exports the standard SSL/TLS related `SSL_*' environment variables.
    #     Per default this exportation is switched off for performance reasons,
    #     because the extraction step is an expensive operation and is usually
    #     useless for serving static content. So one usually enables the
    #     exportation for CGI and SSI requests only.
    #   o StrictRequire:
    #     This denies access when "SSLRequireSSL" or "SSLRequire" applied even
    #     under a "Satisfy any" situation, i.e. when it applies access is denied
    #     and no other module can change it.
    #   o OptRenegotiate:
    #     This enables optimized SSL connection renegotiation handling when SSL
    #     directives are used in per-directory context.
    #SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
    <Files ~ "\.(cgi|shtml|phtml|php3?)$">
        SSLOptions +StdEnvVars
    </Files>
    <Directory "/var/www/cgi-bin">
    </Directory>
    #   SSL Protocol Adjustments:
    #   The safe and default but still SSL/TLS standard compliant shutdown
    #   approach is that mod_ssl sends the close notify alert but doesn't wait for
    #   the close notify alert from client. When you need a different shutdown
    #   approach you can use one of the following variables:
    #   o ssl-unclean-shutdown:
    #     This forces an unclean shutdown when the connection is closed, i.e. no
    #     SSL close notify alert is send or allowed to received.  This violates
    #     the SSL/TLS standard but is needed for some brain-dead browsers. Use
    #     this when you receive I/O errors because of the standard approach where
    #     mod_ssl sends the close notify alert.
    #   o ssl-accurate-shutdown:
    #     This forces an accurate shutdown when the connection is closed, i.e. a
    #     SSL close notify alert is send and mod_ssl waits for the close notify
    #     alert of the client. This is 100% SSL/TLS standard compliant, but in
    #     practice often causes hanging connections with brain-dead browsers. Use
    #     this only for browsers where you know that their SSL implementation
    #     works correctly.
    #   Notice: Most problems of broken clients are also related to the HTTP
    #   keep-alive facility, so you usually additionally want to disable
    #   keep-alive for those clients, too. Use variable "nokeepalive" for this.
    #   Similarly, one has to force some clients to use HTTP/1.0 to workaround
    #   their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
    #   "force-response-1.0" for this.
    BrowserMatch "MSIE [2-5]" \
             nokeepalive ssl-unclean-shutdown \
             downgrade-1.0 force-response-1.0
    #   Per-Server Logging:
    #   The home of a custom SSL log file. Use this when you want a
    #   compact non-error SSL logfile on a virtual host basis.
    CustomLog logs/ssl_request_log \
              "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
    </VirtualHost>
/etc/httpd/conf/httpd.conf**
# This is the main Apache HTTP server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so 'log/access_log'
# with ServerRoot set to '/www' will be interpreted by the
# server as '/www/log/access_log', where as '/log/access_log' will be
# interpreted as '/log/access_log'.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path.  If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used.  If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
ServerRoot "/etc/httpd"
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
Include conf.modules.d/*.conf
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User apache
Group apache
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. admin@your-domain.com
ServerAdmin root@localhost
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
#ServerName www.example.com:80
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
    AllowOverride all
    Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
# Relax access to content within /var/www.
<Directory "/var/www">
    AllowOverride all
    # Allow open access:
    Require all granted
</Directory>
# Further relax access to the default document root:
<Directory "/var/www/html">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   Options FileInfo AuthConfig Limit
    AllowOverride all
    # Controls who can get stuff from this server.
    Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
    DirectoryIndex index.html
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "logs/error_log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here.  Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    #CustomLog "logs/access_log" common
    # If you prefer a logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    CustomLog "logs/access_log" combined
</IfModule>
<IfModule alias_module>
    # Redirect: Allows you to tell clients about documents that used to
    # exist in your server's namespace, but do not anymore. The client
    # will make a new request for the document at its new location.
    # Example:
    # Redirect permanent /foo http://www.example.com/bar
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
</IfModule>
# "/var/www/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
    AllowOverride None
    Options None
    Require all granted
</Directory>
<IfModule mime_module>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig /etc/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    #AddHandler cgi-script .cgi
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    AddType text/html .shtml
    AddOutputFilter INCLUDES .shtml
</IfModule>
# Specify a default charset for all content served; this enables
# interpretation of all content as UTF-8 by default.  To use the
# default browser choice (ISO-8859-1), or to allow the META tags
# in HTML content to override this choice, comment out this
# directive:
AddDefaultCharset UTF-8
<IfModule mime_magic_module>
    # The mod_mime_magic module allows the server to use various hints from the
    # contents of the file itself to determine its type.  The MIMEMagicFile
    # directive tells the module where the hint definitions are located.
    MIMEMagicFile conf/magic
</IfModule>
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults if commented: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
EnableSendfile on
# Enable HTTP/2 by default
# https://httpd.apache.org/docs/2.4/mod/core.html#protocols
<IfModule mod_http2.c>
    Protocols h2 h2c http/1.1
</IfModule>
# Supplemental configuration
# Load config files in the "/etc/httpd/conf.d" directory, if any.
IncludeOptional conf.d/*.conf
<VirtualHost *:443>
     DocumentRoot /var/www/html
     ServerName todomaster.co
     SSLEngine on
     SSLCertificateFile /etc/letsencrypt/live/todomaster.co/fullchain.pem
     SSLCertificateKeyFile /etc/letsencrypt/live/todomaster.co/privkey.pem
</VirtualHost>
I’ve been doing some looking around and there are definitely issues. Sadly, I’m not the best at correcting these particular issues. There are several people who specialize in fixing these particular issues who should be around sometime within the next 8 hours or so. Based on the information you’ve provided they should be able to get you going. I’ll check back in the morning (for me) and hopefully by then you will have gotten a clear direction.
DO I have to edit /etc/httpd/conf.d/ssl.conf file too to insert the cert files location.Please someone help me on this.
equals a buggy config
Apache is notorious for running at all cost.
[which means even though the config "runs" it may be far from perfect]
I agree.
^that is where you should put your config files.
So you have inserted an HTTPS/TLS section (in your base config file).
You still need an HTTP section or you will never be able to renew this cert (this way).
We still haven't seen any of the files in the conf.d folder.
Please show file:
sudo cat /etc/httpd/conf.d/ssl.conf
Thanks for the assist @rg305. :slightly_smiling_face:
I noticed that he stated this after having run sudo certbot certificates, which showed the certificate:
They show the err msg but don’t show HOW they got it.
I suspect they just needed to add sudo in front of w/e they did and that err msg would NOT have shown.
[look a squirrel! and it’s chasing a red herring!]
Euh, yes, @JuergenAuer pointed that out immediately after the post with that error and the post after that contains the output of sudo httpd -S without the error, as predicted. So nothing to see there (the error), move along now people.. :stuck_out_tongue:
@Osiris
I felt like this:
was referring to this:
What do either of those have to do with the following? I'm not being cynical. I am genuinely curious. Did httpd -S only show this without sudo? The two posts (the OP's error and JuergenAuer's sudo) happened within seconds of each other last night, so I didn't put them together.
  1. Is the file actually empty?
    If yes, panic! [the sky has fallen]
    If no, then reissue the command (that generated the err msg) with the proper user creds and show that result.
  2. Show the rest of the config that hasn’t already been shown:
httpd -S ran as non-root fails when it encounters a file it can't open. You should think it could output the rest of the info it gathered anyway, but it doesn't. It only outputs the error (including in my Apaches case the culprit file and line number where the referenced file is encountered).
That helps a lot @Osiris. Thanks. I was so confused when he posted that. I was hoping the OP hadn’t lost the cert somehow in the middle.
Please: It's a known curious thing that running something -S without sudo says, the certificate is missing.
But there is no missing certificate, it's only the missing root / sudo.
And
has the complete answer, 11 hours old.
If there is a redirect https + non-www -> https + www, but the port 443 vHost hasn't the www (see the result of sudo httpd -S), the default vHost answers - and the certificate is wrong.
That's a completely expected result.
More reading, less speculation would be helpful.
@JuergenAuer
I, for one, was not aware of the no-sudo no-cert issue. As a software engineer who has trained SAT teams, I would say the “missing certificate” is a very goofy response from httpd, but I suppose it’s just an artifact of how the error-handling is done. Perhaps “hey, I can’t open this file.” would be much more useful. Thanks for informing me about this though. I’ll look out for it going forward. :slightly_smiling_face:
I fully concur with your conclusions as to the solution. Unfortunately, as is obvious from the OP’s posts and configuration, the OP is not too familiar with these aspects and therfore rather lost. Admittedly, you are right that the responsibility is with the OP and it really isn’t the job of this community to fix these things. I also don’t want to give people a bad impression of the community by browbeating them for being novices. I have no doubt that you are an absolute master Juergen in what I would presume is every area of the tech here. You were once a novice too, I think. Help is good, but if you damage someone’s self-esteem and/or motivation, I don’t know how much progress they’re going to make or if they’re going to trust the community in the future.
I have configured /etc/httpd/conf.d/ssl.conf and now it is working, thanks everyone for your help.
The next thing you need to do is address your insecure content.
https://www.whynopadlock.com/results/a05af93f-f93b-4174-a3d2-b98d036c633c
