K8S + Nginx Ingress Controller + Private datacenter Configuration is not working
My domain is: lab.k5s.xyz
ENV:
I have setup a K8S cluster in private data center, and installed Nginx Ingress Controller with host network and Cert-Manger.
I have a public domain lab.k5s.xyz, due to there is no public in data center, so I add a A record in DNS *.lab.k5s.xyz point to the private IP of the node which Nginx Ingress Controller pod running.
I have tried to use http-0, but i got the error “Accepting challenge authorization failed: acme: authorization error for demo.lab.k5s.xyz: 400 urn:ietf:params:acme:error:dns: No valid IP addresses found for demo.lab.k5s.xyz”.
Question:
Can I using Cert-Manager to issue the SSL certificate? if yes, which validation method is ok? http-01 or DNS?
How can I make it works? thanks!
Br, Wayne
Hi @wwyhy
if you want to use http validation, a correct A-record yourDomain -> yourIP is required.
But there - https://check-your-website.server-daten.de/?q=lab.k5s.xyz - is no public ip address.
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
lab.k5s.xyz A yes 1 0
AAAA yes
www.lab.k5s.xyz A 10.71.21.163 No Hostname found yes 1 0
AAAA yes
*.k5s.xyz A Name Error yes
AAAA Name Error yes
CNAME Name Error yes
*.lab.k5s.xyz A 10.71.21.163 yes
10.71.21.163 is a private ip address. So that can’t work, Letsencrypt can’t connect your server.
If you don’t have a public ip address, you must use dns validation.
