Authorizing Identifier dezuidkolk.nl Using Challenge Type http-01
Unexpected error
ACME Server Returned:
“type”: “urn:acme:error:badNonce”,
“detail”: “JWS has invalid anti-replay nonce oFrxrsYCvfaVWtPbt0IK_RRtJcShF0F1K6QoCL2EqKk”,
“status”: 400
IIS 10.0.14393.0
Windows Server 2016
My hosting provider, if applicable, is: TransIP.net BladeServer
Yes
No
I don’t know exactly what you mean, but I retried manually. (I mean, I ran the exact same command line command again.)
And this time the (san) certificate got renewed without any problems…
I'm glad that you were able to solve the problem by retrying manually. I flagged @WouterTinus because he's the developer of the Let's Encrypt Win Simple program. Ideally that program would automatically retry when it sees this error so that you wouldn't have to
In my experience this happens when there is too much time between the
initialization of an AcmeClient object and its eventual use to call the
Let’s Encrypt API. For example when the user spends several minutes idle in
the menu. In the upcoming release (currently in beta) the AcmeClient has a
much shorter lifetime and is only created after all the user input has been
gathered, so it shouldn’t be a problem anymore.
You’re correct, that’s definitely one reason that a bad nonce error can happen. I’m happy to hear LEWS will try to reduce the lifetime between when a nonce is retrieved vs used. That should help with this case as you suggest.
Have you considered allowing retries for badNonce errors anyway? It’s possible that they could occur for reasons other than aging out. The ACME specification says the following:
An error response with the “badNonce” error type MUST include a Replay-Nonce header with a fresh nonce. On receiving such a response, a client SHOULD retry the request using the new nonce.
Thanks for chiming in @WouterTinus! I appreciate it!
@cpu I think that’s a great idea, though I feel that such a change would be best at home in the ACMESharp library which LEWS and some other .NET-based tools are built on, so that they all benefit. That’s not to say I wouldn’t to a PR to Eugene Bekker though.
