Dear Community,
I am coding a simple Java Socket Framework with an SSL/TLS integration.
I had many Problems with the SSL/TLS integrations, but I fixed all, only the generation of a Let's Encrypt Certificate failed.
Likewise, I am using a KeyStore File for storing my chains and the intermediate cert, but there's a problem I think.
Because the Browser didn't display the Certificate only on localhost where the Domain is not the same.
When I test the cert via the OpenSSL Client, I get the following Message:
Verification error: unable to get local issuer certificate
So I think the error belongs to my generation of the Cert...
To tell you a bit more, here's my current Template of generating the Cert:
Oder PKCS12 (Java)
# generate cert
certbot certonly
# convert chain + private to PKCS#12
openssl pkcs12 -export -out keystore.pkcs12 -in fullchain.pem -inkey privkey.pem
# convert PKCS#12 to JKS
keytool -importkeystore -srckeystore keystore.pkcs12 -srcstoretype PKCS12 -destkeystore keystore.jks
rm keystore.pkcs12
Thanks for your Help.
Regards
Jan
What is the OpenSSL command you're using to test with? Does it specify an explicit trust store? I'm not an OpenSSL expert, but I seem to recall it doesn't always use the OS's trust store automatically.
Hey, I am using openssl s_client -showcerts -connect my-triox.de:443 to test my Cert.
If you don't have a copy available already, download the ISRG Root X1 certificate and then update your command with the -CAfile parameter like this:
openssl s_client -showcerts -CAfile /path/to/isrgrootx1.pem -connect my-triox.de:443
Okay, i think that i am getting the right now.
CONNECTED(000001A0)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = my-triox.de
verify return:1
Certificate chain
0 s:CN = my-triox.de
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
i:O = Digital Signature Trust Co., CN = DST Root CA X3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Server certificate
subject=CN = my-triox.de
issuer=C = US, O = Let's Encrypt, CN = R3
Acceptable client certificate CA names
C = DE, ST = Hessen, L = Kronberg im Taunus, O = Byte-Store.DE, OU = Byte-Store.DE, CN = My-TrioX.DE
Requested Signature Algorithms: ECDSA+SHA256:ECDSA+SHA384:ECDSA+SHA512:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA512:ECDSA+SHA1:RSA+SHA1
Shared Requested Signature Algorithms: ECDSA+SHA256:ECDSA+SHA384:ECDSA+SHA512:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA-PSS+SHA256:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA512
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 5133 bytes and written 874 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 2048 bit
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
38004:error:14094412:SSL routines:ssl3_read_bytes:sslv3 alert bad certificate:ssl\record\rec_layer_s3.c:1544:SSL alert number 42
But how can i bring that to the Browser?
I don't follow. Bring what to the browser?
rg305
July 9, 2021, 12:15am
7
