Issues with using certbot for the first time
My domain is: www.livify.app
I ran this command: sudo certbot --nginx --rsa-key-size 4096 --no-redirect
[root@ip-172-31-29-237 ec2-user]# sudo certbot --nginx --rsa-key-size 4096 --no-redirect
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: livify.app
2: www.livify.app
Requesting a certificate for livify.app and www.livify.app
  Domain: livify.app
  Type:   unauthorized
  Detail: 13.57.133.254: Invalid response from http://livify.app/.well-known/acme-challenge/TBMRsp3pv49jT_t7ctjOZ8Qx_Ht8EwX2fMxexwPomz8: 404
  Domain: www.livify.app
  Type:   unauthorized
  Detail: 13.57.133.254: Invalid response from http://www.livify.app/.well-known/acme-challenge/ZkgazTKSZiL2lFL2OP2OwgLnyMDL43h5ggH9GQX55sc: 404
The operating system my web server runs on is (include version): centos 7
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.30.0
My guess why this isn't working is possibly because I use an elastic IP which is the one that is on the detail line, Detail: 13.57.133.254, but this is not the same one that prints out when I use ifconfig. I'm not quite sure. Any and all help is extremely appreciated!
Welcome to the community @jasonn9538
Yes, normally the Elastic IP is correct. You can confirm the public IP of your server running a command like this too:
curl -4 https://ifconfig.co
curl -6 https://ifconfig.co  (if using IPv6)
Right now it looks like you changed your DNS and using an internal AWS IP. That won't work. If you change your DNS back to the public IP (confirmed using the curl commands) we can look into it more.
Otherwise you get a failure now shown by this Let's Debug test site
@MikeMcQ thanks for your reply. I just reverted the IP that livify.app directs to using the IP address from the ipv4 curl command. Can you take a look again? I receive the same error. Here is the error log with "-v"
[root@ip-172-31-29-237 ec2-user]# sudo certbot --nginx --rsa-key-size 4096 --no-redirect -v
1: livify.app
2: www.livify.app
http-01 challenge for livify.app
http-01 challenge for www.livify.app
Challenge failed for domain www.livify.app
Challenge failed for domain livify.app
  Type:   unauthorized
  Detail: 13.57.133.254: Invalid response from http://www.livify.app/.well-known/acme-challenge/QhU_nA-sHxBldPnO8Kzxtdf2Yk2hwNCzZvv7YhKtGL0: 404
  Domain: livify.app
  Type:   unauthorized
  Detail: 13.57.133.254: Invalid response from http://livify.app/.well-known/acme-challenge/bRCTx4IxQRpwgomGShrDKHVA9k8Bd_h_WkT7pnBsLVE: 404
Is nginx running directly on that AWS instance? And a standard OS nginx install, not a Bitnami setup or something?
schoen asks good questions. The 404 error you got is unusual when using the nginx plug-in as you are. Would be helpful to know more details of your setup. Is it just a plain EC2 instance with nginx?
You might also try restarting the server. It is possible to get in a bad state with two variations of nginx running (under systemd and outside it). If, for example, you tried running certbot --nginx when nginx was not running this can happen and cause problems.
If nothing seems helpful we could look at the full debug log. You can upload it with a post here but may need to copy it to a .txt file first. Or, copy/paste the entire thing (very long) here but then please add 3 backticks before and after like this:
pasted contents of /var/log/letsencrypt/letsencrypt.log
If all else fails, you might want to try using --webroot authentication.
