Issues with nginx
My domain is: ldapwiki.com
certbot certonly --webroot --agree-tos --email jim@willeke.com -w /var/www/letsencrypt -d ldapwiki.com -d www.ldapwiki.com
Failed authorization procedure. ldapwiki.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://ldapwiki.com/.well-known/acme-challenge/c
nginx version: nginx/1.10.3 (Ubuntu)
Ubuntu 16.04.3 LTS
linode
Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): N/A
Hi @jwilleke,
Are you sure?. Because seems your site is using Apache Tomcat 7.0.54.
Anyway, to test if this command would work:
Create a test file here: /var/www/letsencrypt/.well-known/acme-challenge/test
Example:
mkdir -p /var/www/letsencrypt/.well-known/acme-challenge/
echo "Testing acme-challenge" > /var/www/letsencrypt/.well-known/acme-challenge/test
And then try to access this file with your browser:
http://ldapwiki.com/.well-known/acme-challenge/test
http://www.ldapwiki.com/.well-known/acme-challenge/test
If you get "Testing acme-challenge" then we will need more info about your config.
If you get an error you should review your config to know what is the web root for your site and place the right path in certbot command...
Cheers,
sahsanu
I believe the issue is with the webroot directory you specified. I would find it surprising that your webroot is /var/www/letsencrypt, and I’m assuming what you did is map that to /.well-known/acme-challenge instead. This will cause certbot to serve the file at /.well-known/acme-challenge/.well-known/acme-challenge, because webroot expects the directory at which you are serving /.
lsof -i :80
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
nginx 1272 root 6u IPv4 337596 0t0 TCP *:http (LISTEN)
nginx 1272 root 7u IPv6 337597 0t0 TCP *:http (LISTEN)
nginx 4952 www-data 6u IPv4 337596 0t0 TCP *:http (LISTEN)
nginx 4952 www-data 7u IPv6 337597 0t0 TCP *:http (LISTEN)
nginx 4953 www-data 6u IPv4 337596 0t0 TCP *:http (LISTEN)
nginx 4953 www-data 7u IPv6 337597 0t0 TCP *:http (LISTEN)
nginx 4954 www-data 6u IPv4 337596 0t0 TCP *:http (LISTEN)
nginx 4954 www-data 7u IPv6 337597 0t0 TCP *:http (LISTEN)
nginx 4955 www-data 6u IPv4 337596 0t0 TCP *:http (LISTEN)
nginx 4955 www-data 7u IPv6 337597 0t0 TCP *:http (LISTEN)
So pretty sure nginx is working on port 80.
The config file (Well one them with
configuration file /etc/nginx/sites-available/tomcat-proxy.conf:
Basic Proxy for ROOT Wiki
listen 80;
server_name ldapwiki.com, www.ldapwiki.com;
root /usr/share/tomcat/webapps/ROOT/;
index index.jsp index.html index.htm;
Add robots.txt
location /robots.txt {
alias /usr/share/tomcat/webapps/ROOT/robots.txt;
default_type “text/plain”;
root /var/www/letsencrypt;
try_files $uri $uri/ =404;
location ~ .jsp$ {
proxy_pass http://127.0.0.1:8080;
location ~* .(jpg|jpeg|png|gif|ico|css|js)$ {
expires 1M;
Really appreciate the help as have worked on this for too many hours.
If I remember correctly, this maps /.well-known/acme-challenge on the site to /var/www/letsencrypt instead of the intended /var/www/letsencrypt/.well-known/acme-challenge. The correct form would probably be to created /var/www/letsencrypt/.well-known/acme-challenge and then set root /var/www/letsencrypt/.well-known/acme-challenge, or, alternatively, to keep it as it is and create /var/www/letsencrypt/.well-known and then ln -s /var/www/letsencrypt /var/www/letsencrypt/.well-known/acme-challenge.
No, the nginx directive is ok, maybe you are confusing root with alias. alias directive has the behaviour your are explaining.
“location with root inside” seems confusing.
I’ve always seen “location with alias inside”.
Like:
location /.well-known {
alias /var/www/letsencrypt/.well-known;
Ok. For me, your tomcat-proxy.conf is ok so the problem should be in another side. I suppose you already enabled this conf right?. I mean, is there a link in /etc/nginx/sites-enabled/tomcat-proxy.conf pointing to /etc/nginx/sites-available/tomcat-proxy.conf?.
Could you please also check if you have some kind of port forwarding from port 80 to 8080?. I'm asking because I'm still viewing that your tomcat is answering directly instead of being proxified by nginx.
$ curl -IkL http://ldapwiki.com/.well-known/acme-challenge/test
HTTP/1.1 404 Not Found
Server: Apache-Coyote/1.1
Content-Type: text/html;charset=utf-8
Content-Language: en
Content-Length: 1013
Date: Mon, 28 Aug 2017 18:28:51 GMT
Cheers,
sahsanu
