Issues renewing certificate on Ubuntu 18.04.6 LTS
My domain is: unifi.penntech-it.com
I ran this command: sudo certbot --force-renewal -d unifi.penntech-it.com
http-01 challenge for unifi.penntech-it.com
Enabled Apache rewrite module
Created an SSL vhost at /etc/apache2/sites-available/000-default-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/000-default-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/000-default-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Redirecting vhost in /etc/apache2/sites-enabled/000-default.conf to ssl vhost in /etc/apache2/sites-available/000-default-le-ssl.conf
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://unifi.penntech-it.com
https://www.ssllabs.com/ssltest/analyze.html?d=unifi.penntech-it.com
    /etc/letsencrypt/live/unifi.penntech-it.com/fullchain.pem
    /etc/letsencrypt/live/unifi.penntech-it.com/privkey.pem
    Your cert will expire on 2022-05-08. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2022-01-05T14:50:41
Ubuntu 18.04.6 LTS (GNU/Linux 5.4.0-1068-azure x86_64
Azure
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Control panel and CLI
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.27.0
I appear to have successfully renewed the certificate, I restarted the server however when I browse to https://unifi.penntech-it.com:8443 it still shows that the certificate is not valid
HI @craig8 and welcome to the LE community forum :slight_smile:
Please show the outputs of:
apachectl -t -D DUMP_VHOSTS
netstat -pant | grep -i listen
Also, stay away from using --force-renewal
[nothing good comes from using it for regular renewals - never add it to any script]
Hi @rg305
Thanks for coming back to me, please see outputs below... first command is interesting!
Ubiquiti_Admin@UbiquitiUCC:~$ apachectl -t -D DUMP_VHOSTS
AH00526: Syntax error on line 33 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/unifi.penntech-it.com/fullchain.pem' does not exist or is empty
Action '-t -D DUMP_VHOSTS' failed.
Ubiquiti_Admin@UbiquitiUCC:~$ netstat -pant | grep -i listen
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
tcp 0 0 127.0.0.1:27117 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp6 0 0 :::8443 :::* LISTEN -
tcp6 0 0 :::443 :::* LISTEN -
tcp6 0 0 :::6789 :::* LISTEN -
tcp6 0 0 :::8843 :::* LISTEN -
tcp6 0 0 :::8880 :::* LISTEN -
tcp6 0 0 :::8080 :::* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
Try:
sudo apachectl -t -D DUMP_VHOSTS
sudo netstat -pant | grep -i listen
Did you move that?
Show us this file, please.
@rg305
Ubiquiti_Admin@UbiquitiUCC:~$ sudo apachectl -t -D DUMP_VHOSTS
[sudo] password for Ubiquiti_Admin:
VirtualHost configuration:
*:443 unifi.penntech-it.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 ubiquitiucc.internal.cloudapp.net (/etc/apache2/sites-enabled/000-default.conf:1)
Ubiquiti_Admin@UbiquitiUCC:~$ sudo netstat -pant | grep -i listen
tcp 0 0 127.0.0.1:27117 0.0.0.0:* LISTEN 1689/bin/mongod
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 820/systemd-resolve
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1055/sshd
tcp6 0 0 :::8443 :::* LISTEN 1542/java
tcp6 0 0 :::443 :::* LISTEN 1073/apache2
tcp6 4 0 :::6789 :::* LISTEN 1542/java
tcp6 0 0 :::8843 :::* LISTEN 1542/java
tcp6 0 0 :::8880 :::* LISTEN 1542/java
tcp6 0 0 :::8080 :::* LISTEN 1542/java
tcp6 0 0 :::80 :::* LISTEN 1073/apache2
tcp6 0 0 :::22 :::* LISTEN 1055/sshd
@9peppe
No didnt move any files
File contents:
# The ServerName directive sets the request scheme, hostname and port that # the server uses to identify itself. This is used when creating # redirection URLs. In the context of virtual hosts, the ServerName # specifies what hostname must appear in the request's Host: header to # match this virtual host. For the default virtual host (this file) this # value is not decisive as it is used as a last resort host regardless. # However, you must set it for any further virtual host explicitly. #ServerName www.example.com
    DocumentRoot /var/www/html
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
ServerName unifi.penntech-it.com
SSLCertificateFile /etc/letsencrypt/live/unifi.penntech-it.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/unifi.penntech-it.com/privkey.pem
Based on the netstat command you have java listening on port 8443. You will need to copy over the Let's Encrypt cert you just got to your java server. Certbot only is able to configure Apache or nginx.
That java server currently sends a Let's Encrypt cert that expired a long time ago
THIS IS JUST FOR RENEWING
The shorter name is only served via HTTPS.
You can probably (indirectly) "use" that vhost with:
certbot --webroot -w /document/root/path -d unifi.penntech-it.com
You can find the actual DocumentRoot used in the file:
USING THE CERT
Will require going through whatever steps were taken originally to get the Java app to use a cert.
Managed to get this sorted, found the old article I used to initially set this up and just needed to run the following command to import the SSL into the controller: sudo /usr/local/bin/unifi_ssl_import.sh
Only thing is I am not sure now how to configure this to auto-renew
The guide shows how to automate the renewals.
Let's begin at the beginning...
Please show the output of:
sudo certbot certificates
