Issues renewing an SSL certificat- certbot
Hello,
This is my first topic here but a few days ago something happened that I can’t explain. I’ve been using Certbot on multiple domains/servers for almost half a year now - maybe even more. And yesterday mine web app didn’t renew the certificate so it was unreachable. I now restore the digital ocean droplet back for 3 days, so I have a bit more time to find the issue.
This happens if I want to renew the certificate:
       Domain: app.instalgic.com
       Type:   unauthorized
       Detail: Invalid response from
       http://app.instalgic.com/.well-known/acme-challenge/RsWB5-XmCT6WK8CYRkrAZxWI1PfQZSsBF3VctyTzKOw:
       "<!DOCTYPE html>\n<html>\n    <head>\n        <meta
       charset=\"utf-8\">\n        <meta http-equiv=\"X-UA-Compatible\"
       content=\"IE=edge\">\n "
    You have new mail in /var/mail/root
Could someone try to help me out? I did everything I could, but I have no idea why suddenly I can’t renew.
Hi @askejlacen
perhaps you have used tls-sni-01 validation. This is deprecated, support ends 2019-02-13, so your certbot switches to http-01 validation.
That means: Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks this file.
But checking your domain I see a different error as Letsencrypt ( https://check-your-website.server-daten.de/?q=app.instalgic.com ):
You have redirects http -> https, this is ok, Letsencrypt follows, the wrong certificate is ignored.
But then the unknown file https://app.instalgic.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de is redirected to your login page. Your login page doesn't have the content Letsencrypt want's to check.
So remove that redirect.
PS: In Help there is a list of questions:
Hey, @JuergenAuer thanks for fast reply.
I’m running my main domain on another server and there the SSL successfully renewed. My main domain is Instalgic.com.
The subdomain in question is: app.instalgic.com
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/app.instalgic.com.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for app.instalgic.com
Attempting to renew cert (app.instalgic.com) from /etc/letsencrypt/renewal/app.i        nstalgic.com.conf produced an unexpected error: Failed authorization procedure.        app.instalgic.com (http-01): urn:ietf:params:acme:error:unauthorized :: The clie        nt lacks sufficient authorization :: Invalid response from http://app.instalgic.        com/.well-known/acme-challenge/YFLUEWpTcqMTUGC_28RywFriAGQeOuG3u9fHnjQAATE: "<!D        OCTYPE html>\n<html>\n    <head>\n        <meta charset=\"utf-8\">\n        <met        a http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n ". Skipping.
  /etc/letsencrypt/live/app.instalgic.com/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
**          (The test certificates above have not been saved.)
   Type:   unauthorized
   http://app.instalgic.com/.well-known/acme-challenge/YFLUEWpTcqMTUGC_28RywFriA        GQeOuG3u9fHnjQAATE:
Distributor ID: Ubuntu
Description: Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
Apache / 2.4.18 (Ubuntu)
DigitalOcean
Yes
Certbot version:
certbot 0.26.1
This is also some content from letsencrypt.log
2019-02-02 14:16:31,793:DEBUG:certbot.error_handler:Calling registered functions
2019-02-02 14:16:31,793:INFO:certbot.auth_handler:Cleaning up challenges
2019-02-02 14:16:32,110:WARNING:certbot.renewal:Attempting to renew cert (app.instalgic.com) from /etc/letsencrypt/renewal/app.instalgic.com.conf produced an unexpected error: Failed authorization procedure. app.instalgic.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://app.instalgic.com/.well-known/acme-challenge/YFLUEWpTcqMTUGC_28RywFriAGQeOuG3u9fHnjQAATE: "<!DOCTYPE html>\n<html>\n    <head>\n        <meta charset=\"utf-8\">\n        <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n ". Skipping.
2019-02-02 14:16:32,114:DEBUG:certbot.renewal:Traceback was:
  File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 430, in handle_renewal_request
    main.renew_cert(lineage_config, plugins, renewal_candidate)
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 1197, in renew_cert
    renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 115, in _get_and_save_cert
    renewal.renew_cert(config, domains, le_client, lineage)
  File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 305, in renew_cert
    new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
  File "/usr/lib/python3/dist-packages/certbot/client.py", line 334, in obtain_certificate
  File "/usr/lib/python3/dist-packages/certbot/client.py", line 370, in _get_order_and_authorizations
    authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
  File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 82, in handle_authorizations
    self._respond(aauthzrs, resp, best_effort)
  File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 155, in _respond
    self._poll_challenges(aauthzrs, chall_update, best_effort)
  File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 226, in _poll_challenges
    raise errors.FailedChallenges(all_failed_achalls)
certbot.errors.FailedChallenges: Failed authorization procedure. app.instalgic.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://app.instalgic.com/.well-known/acme-challenge/YFLUEWpTcqMTUGC_28RywFriAGQeOuG3u9fHnjQAATE: "<!DOCTYPE html>\n<html>\n    <head>\n        <meta charset=\"utf-8\">\n        <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n "
2019-02-02 14:16:32,116:ERROR:certbot.renewal:All renewal attempts failed. The following certs could not be renewed:
2019-02-02 14:16:32,117:ERROR:certbot.renewal:  /etc/letsencrypt/live/app.instalgic.com/fullchain.pem (failure)
2019-02-02 14:16:32,117:DEBUG:certbot.log:Exiting abnormally:
  File "/usr/bin/certbot", line 11, in <module>
    load_entry_point('certbot==0.26.1', 'console_scripts', 'certbot')()
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 1364, in main
  File "/usr/lib/python3/dist-packages/certbot/main.py", line 1276, in renew
    renewal.handle_renewal_request(config)
  File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 455, in handle_renewal_request
    len(renew_failures), len(parse_failures)))
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
This is really not related to this server and cert request.
So we will ignore that and focus on this server and cert.
This config:
directs certbot to use:
It would seem that those are now unable to properly determine the location of the challenge response.
Using -vv (or greater) may show exactly where certbot is placing that challenge response.
But that may not fix the problem.
The bigger problem is what is in the config that "confuses" certbot into placing it there (in an inaccessible location).
We could spend time on that...
Or just force it to go to the correct location (or a specific location) and be done with this.
To check where it should be going based on the config, we would need to see the current config.
And then use --webroot to ensure it uses that location.
To force it to a specific location, you can use an Alias directive to map the /.well-known/acme-challenge/ requests to a folder of your choosing.
