From a newbie to certbot but used to command line linux.
Run a vps with root access and host multiple (small) domains. Now trying to upgrade most to https: and also
encrypt the (sendmail/dovecot) mail server instead of plain text passwords.
I have installed:-
certbot 1.0.0-1.el7
pythoin2-certbot 1.0.0-1.el7
python2-certbot-nginx 1.0.0-1el7
Running Centos 7-7.1908.0.el7.centos
From the root command line I am running
[root@server ~]#
certbot -d an2.co.uk --apache
The requested apache plugin does not appear to be installed
Apache is running but the .conf file is httpd.conf and I use the include command withing the .conf file to include multiple .conf files, one for each domain (i.e. an2.co.uk.conf)
I have read pages of documentation but can not find what is wrong here!!
Error log says:-
2020-01-01 13:09:50,509:DEBUG:certbot._internal.main:certbot version: 1.0.0
2020-01-01 13:09:50,509:DEBUG:certbot._internal.main:Arguments: [’-d’, ‘an2.co.uk’, ‘–apache’]
2020-01-01 13:09:50,509:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-01-01 13:09:50,532:DEBUG:certbot._internal.log:Root logging level set at 20
2020-01-01 13:09:50,532:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-01-01 13:09:50,534:DEBUG:certbot._internal.plugins.selection:Requested authenticator apache and installer apache
2020-01-01 13:09:50,534:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2020-01-01 13:09:50,534:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
www.an2.co.uk uses an invalid security certificate. The certificate is only valid for an2.co.uk Error code: SSL_ERROR_BAD_CERT_DOMAIN
When installing the certificate I used the command line
SHOULD I ENTER HERE EVERY VERSION OF THE DOMAIN? and if so how do I replace the existing certificate.
Many thanks, now typed all the host names and created the certificate OK
Also looks like I can separate the domains after -d with just a comma, which will
make it easier with others. have to have all together as for instance I run the locaL
Tourist site (WWW.VISIT-WATCHET.CO.UK) and we own all the .suffix domains in
case of domain squatters! Hence the need to cover them all.
I have one more question I am trying to research - using https://www.visit-watchet.co.uk/Leaflets.htm
gives errors in Firefox with a) the broken security symbol and says some content is insecure. and b) all formatting is lost - just this one page! Does anyone know why this is happening?
Now just added the “s” to the css link and all is fine…that would have baffled me for hours and been at
this for a long time! Really just a programmer here in machine code for microprocessors and learning on the fly about odd things! Also added “s” to link to images.
At present have disabled now the auto redirect (commented out) as we have a live camera feed that needs sorting.
Last (honest) question!
I have used the certbot option to switch all calls to https:// which adds the redirect to the virtual host .conf file so can follow that, but does this slow things down as the normal http: is what everyone knows and is published everywhere.
Most of my links are such as img src="\Photos\Photo1.jpg" Will I need to put the full path into all of these for fast loading of images(hhtps://visitwatchet.co.uk/Photos/Photo1.jpg) or will the redirects work for everything without repeated hits on server? OR is there a short way to do the link with https:
