Issue with renewing certificate - Error getting validation data
I am renewing certificate for domain frombaltic.ru using certbot-auto renew.
However, the output is quite generic:
Domain: www.frombaltic.ru
Type: connection
Detail: Fetching
http://www.frombaltic.ru/.well-known/acme-challenge/tFKDT1kgB4SwJA79bMiQ4M4EvbEcjwASRcc_b6tsns4:
I am running it on a digital ocean instance with quite an old Ubuntu installation using nginx.
https://letsdebug.net/www.frombaltic.ru/2647
Redirect loop.
Wow! Thanks! Will look into nginx configs and try to sort it out from there!
Hi @krbchnk
now the redirect loop is fixed. And you have already a new letsencrypt-certificate. Valid from 2018-07-16, Monday.
So this part works.
But you should fix your mixed content warnings. Firefox / Chrome (Desktop), then Ctrl + Shift + i, there select the console. Something like
http://frombaltic.ru/wp-content/uploads/2017/06/skipped
should be https
Okay, found an issue with the redirect. Now have the following message return at unsuccessful ./certbot-auto renew:
   Type:   unauthorized
   Detail: Invalid response from
   http://www.frombaltic.ru/.well-known/acme-challenge/0Fd0cJyEAN4j3gRFwbU1nPPQfskKDo5r3EsCJltl4Q4:
   "<html>
   <head><title>404 Not Found</title></head>
   <body bgcolor="white">
   <center><h1>404 Not Found</h1></center>
   <hr><center>"
contain(s) the right IP address
Try
./certbot-auto renew -a nginx --dry-run
Otherwise please post the full log from /var/log/letsencrypt.log.
Hmmmmm, surprisingly, dry-run was successful, and then the actual renew with -a was successful!
Not sure what the actual problem was, but now everything is fine and works! Thank you!!!!
