Issue with renewing cert with bitwarden
My domain is: pandanet.mynetgear.com
I ran this command: sudo ./bitwarden.sh updatecert
 _     _ _                         _
| |__ (_) |___      ____ _ _ __ __| | ___ _ __
| '_ \| | __\ \ /\ / / _` | '__/ _` |/ _ \ '_ \
| |_) | | |_ \ V  V / (_| | | | (_| |  __/ | | |
|_.__/|_|\__| \_/\_/ \__,_|_|  \__,_|\___|_| |_|
Open source password management solutions
Copyright 2015-2021, 8bit Solutions LLC
https://bitwarden.com, https://github.com/bitwarden
bitwarden.sh version 1.39.4
Docker version 20.10.7, build f0df350
docker-compose version 1.28.5, build c4eb3a1f
Pulling mssql         ... done
Pulling web           ... done
Pulling attachments   ... done
Pulling api           ... done
Pulling identity      ... done
Pulling sso           ... done
Pulling admin         ... done
Pulling portal        ... done
Pulling icons         ... done
Pulling notifications ... done
Pulling events        ... done
Pulling nginx         ... done
Using default tag: latest
latest: Pulling from certbot/certbot
Digest: (not sure if this should be private but im going to snip it just in case)
Status: Image is up to date for certbot/certbot:latest
docker.io/certbot/certbot:latest
Processing /etc/letsencrypt/renewal/pandanet.mynetgear.com.conf
Renewing an existing certificate for pandanet.mynetgear.com
  Domain: pandanet.mynetgear.com
  Type:   connection
  Detail: Fetching http://pandanet.mynetgear.com/.well-known/acme-challenge/rql-rpfrcURjQvdbrBgVOSCj_3EuUiiWbOX9cPBnEJI: Timeout during connect (likely firewall problem)
Hint: The Certificate Authority couldn't exterally verify that the standalone plugin completed the required http-01 challenges. Ensure the plugin is configured correctly and that the changes it makes are accessible from the internet.
Saving debug log to /etc/letsencrypt/logs/letsencrypt.log
Failed to renew certificate pandanet.mynetgear.com with error: Some challenges have failed.
  /etc/letsencrypt/live/pandanet.mynetgear.com/fullchain.pem (failure)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /etc/letsencrypt/logs/letsencrypt.log or re-run Certbot with -v for more details.
vowals@PandaServer:~$
The operating system my web server runs on is (include version):Ubuntu 20.04.2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): whatever bitwarden is using but it claims to be latest
For some context, I noticed that I was getting SSL errors when trying to use bitwarden and so I tried to renew the cert, and I'm getting an error. Any help is much appreciated. I can put the logs in here too I was just worried sensitive info might be in it. Let me know if it's safe to post here. I censored the Digest because it looked like something that was sensitive info but I can post it back if it is important. Also, I already have port 80 allowed on UFW so I don't think it's a firewall issue.
Well, maybe it's bigger than just port 80, because while I can ping your IP address 72.219.177.131, I can't connect to port 80, nor port 443. Or any other regular port for that matter.
Perhaps a home NAT router needs some portmaps?
I have port 80 and 443 already open so i don't think that is the issue unless i misunderstood what portmapping is.
Maybe...
Ports 80 and 443 remain closed:
curl -Iki http://pandanet.mynetgear.com
curl -Iki https://pandanet.mynetgear.com
curl: (7) Failed to connect to pandanet.mynetgear.com port 443: Connection timed out
Port mapping is just port forwarding, right? If so I have them set to open so idk why they would be closed. Could the reason why it's closed be because nothing is using the port rn? Whenever I try to start bitwarden it hangs:
_     _ _                         _
Digest: -snip-
and then gives the same error that I showed above.
Also after attempting to reinstall bitwarden this happend:
vowals@PandaServer:~$ sudo ./bitwarden.sh install
 _     _ _                         _
(!) Enter the domain name for your Bitwarden instance (ex. bitwarden.example.com): pandanet.mynetgear.com
(!) Do you want to use Let's Encrypt to generate a free SSL certificate? (y/n): y
(!) Enter your email address (Let's Encrypt will send you certificate expiration reminders): -snip-
Digest: sha256:1de29b86aa08f09b944b89dc74f1b3a4789b53eb7addeb2b29c276ec730a402f
Account registered.
Requesting a certificate for pandanet.mynetgear.com
  Type:   connection
  Detail: Fetching http://pandanet.mynetgear.com/.well-known/acme-challenge/deXdOUuJ7m-tOzFtrgYKpznOgKskA28u3SK2kGChmlY: Timeout during connect (likely firewall problem)
Is there any other device that could be blocking HTTP or hasn't been configured to NAT/port forward HTTP correctly?
Not that i know of, I had not changed anything before this all happend.
Something is keeping inbound HTTP requests from being heard/responded.
Is there a good way to find out what is? I've been messing around with Nmap, looking at my docker containers, and looking through all the applications open, and can't seem to find anything. Are there any programs or something that may help with the search?
tcpdump or wireshark might be useful.
