Hello there!
First, thanks for this great initiative and project! Been using it for a little bit and love it.
Today I’ve came to an issue with a Expired Certificate (details below) and I could not manually renew it as I got a message of reaching the limit. Oddly enough this is just a simple domain, with not even subdomain and just one certificate. So I follow your documentation and checked the logs at ctr and google transparency:
https://crt.sh/?q=gabrielfariasiribarren.com
https://transparencyreport.google.com/https/certificates
I’ve realize that there are several certificates, with expiry date December 2017?
Checking the server, I’ve realize that the cron job was run daily in the last few days, I this might have be the cause of the issue. I’ve now moved this back to monthly.
However the question is still the same:
Why is it showing a expired certificate even if they appear to be valid?
Is there any way to solve this issue?
Is it there anything I can do rather than just wait for 7 days?
I just want to be sure to find the root cause of the issue to understand it, find a permanent solution and avoid bothering you guys again.
Thanks for your patience and help.
Truly appreciated.
Love.
https://gabrielfariasiribarren.com/
Basically it was a cron job from plesk that runs:
/usr/local/psa/admin/bin/php -dauto_prepend_file=sdk.php ‘/usr/local/psa/admin/plib/modules/letsencrypt/scripts/renew.php’
[2017-09-28 11:23:58] ERR [extension/letsencrypt] Failed to renew certificate of domain ‘gabrielfariasiribarren.com’: Invalid response from https://acme-v01.api.letsencrypt.org/acme/new-cert.
Details:
Type: urn:acme:error:rateLimited
Status: 429
Detail: Error creating new cert :: too many certificates already issued for exact set of domains: gabrielfariasiribarren.com,www.gabrielfariasiribarren.com
Plesk Onyx v17.5.3_build1705170317.16 os_CentOS 7
CentOS Linux 7.4.1708 (Core)
1and1 VPS
Yes
Plesk / Let’s Encript Plugin
