Thanks Jared,
Here it is
2018-08-15 18:35:55,455:DEBUG:certbot.main:certbot version: 0.26.1
2018-08-15 18:35:55,455:DEBUG:certbot.main:Arguments: ['--test-cert', '--apache', '-d', 'phlinux.ovh']
2018-08-15 18:35:55,455:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2018-08-15 18:35:55,463:DEBUG:certbot.log:Root logging level set at 20
2018-08-15 18:35:55,464:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2018-08-15 18:35:55,464:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
2018-08-15 18:35:55,540:DEBUG:certbot_apache.configurator:Apache version is 2.4.10
2018-08-15 18:35:55,880:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin - Beta
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
Initialized: <certbot_apache.override_debian.DebianConfigurator object at 0x7f45e1164e90>
Prep: True
2018-08-15 18:35:55,881:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Prep: True
2018-08-15 18:35:55,881:DEBUG:certbot.plugins.selection:Selected authenticator <certbot_apache.override_debian.DebianConfigurator object at 0x7f45e1164e90> and installer <certbot_apache.override_debian.DebianConfigurator object at 0x7f45e1164e90>
2018-08-15 18:35:55,881:INFO:certbot.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2018-08-15 18:35:55,883:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(status=None, terms_of_service_agreed=None, agreement=None, only_return_existing=None, contact=(), key=None), uri=u'https://acme-staging-v02.api.letsencrypt.org/acme/acct/6641890', new_authzr_uri=None, terms_of_service=None), ed482ad44e317bfd36bb64bfef5c1d3c, Meta(creation_host=u'phlsys.phlinux.ovh', creation_dt=datetime.datetime(2018, 8, 13, 11, 39, 10, tzinfo=<UTC>)))>
2018-08-15 18:35:55,884:DEBUG:acme.client:Sending GET request to https://acme-staging-v02.api.letsencrypt.org/directory.
2018-08-15 18:35:55,901:DEBUG:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
2018-08-15 18:35:56,392:DEBUG:requests.packages.urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 724
2018-08-15 18:35:56,392:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 724
X-Frame-Options: DENY
Expires: Wed, 15 Aug 2018 16:35:56 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Wed, 15 Aug 2018 16:35:56 GMT
"2jMEGBI1xb4": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"keyChange": "https://acme-staging-v02.api.letsencrypt.org/acme/key-change",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"website": "https://letsencrypt.org/docs/staging-environment/"
"newAccount": "https://acme-staging-v02.api.letsencrypt.org/acme/new-acct",
"newNonce": "https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce",
"newOrder": "https://acme-staging-v02.api.letsencrypt.org/acme/new-order",
"revokeCert": "https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert"
2018-08-15 18:35:56,393:INFO:certbot.main:Obtaining a new certificate
2018-08-15 18:35:56,502:DEBUG:certbot.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0022_key-certbot.pem
2018-08-15 18:35:56,503:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0022_csr-certbot.pem
2018-08-15 18:35:56,504:DEBUG:acme.client:Requesting fresh nonce
2018-08-15 18:35:56,504:DEBUG:acme.client:Sending HEAD request to https://acme-staging-v02.api.letsencrypt.org/acme/new-order.
2018-08-15 18:35:56,760:DEBUG:requests.packages.urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "HEAD /acme/new-order HTTP/1.1" 405 0
2018-08-15 18:35:56,761:DEBUG:acme.client:Received response:
HTTP 405
Server: nginx
Content-Type: application/problem+json
Content-Length: 103
Allow: POST
Replay-Nonce: AHgpPCa_yYLItxxTU1JYLDaFm-pj9ia8SgRTVSGSGok
Pragma: no-cache
2018-08-15 18:35:56,761:DEBUG:acme.client:Storing nonce: AHgpPCa_yYLItxxTU1JYLDaFm-pj9ia8SgRTVSGSGok
2018-08-15 18:35:56,761:DEBUG:acme.client:JWS payload:
"status": "pending",
"identifiers": [
"type": "dns",
"value": "phlinux.ovh"
"resource": "new-order"
2018-08-15 18:35:56,762:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJub25jZSI6ICJBSGdwUENhX3lZTEl0eHhUVTFKWUxEYUZtLXBqOWlhOFNnUlRWU0dTR29rIiwgInVybCI6ICJodHRwczovL2FjbWUtc3RhZ2luZy12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0LzY2NDE4OTAiLCAiYWxnIjogIlJTMjU2In0",
"payload": "ewogICJzdGF0dXMiOiAicGVuZGluZyIsIAogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwgCiAgICAgICJ2YWx1ZSI6ICJwaGxpbnV4Lm92aCIKICAgIH0KICBdLCAKICAicmVzb3VyY2UiOiAibmV3LW9yZGVyIgp9",
"signature": "EWHzLiEjXZkZr_8cVNhjvRtXuIoB3iXGV1XA3W8XrFWH3KQTcnfHEtfHoUKTmYWFOiZujMb4Bjvc3PTsyZLFp21r-wW2Q-llwEznrOwlAPQnPVvvVFS7O9bpTKLD_mW7Qwb3pDEiLhJVAoG6hDMq1VpclO-7w8igeMW7lJpIQQTfm7VhSPuIXATUPcd_s2PweOdHQNKyEYhSySn5eXLdtFhbdiZ9d-D6Mzd0iw-bLRUrn1qi5YTmI8iklLFp3tjf9u3frLypzTpngcwOXeorMdBUWZQBmcJ6HAsAqpfjTdDCbTQY3uRJhtW8a8cmdMKTQtodxqSvQL4Jgour7l9BpA"
2018-08-15 18:35:57,031:DEBUG:requests.packages.urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 383
2018-08-15 18:35:57,032:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 383
Boulder-Requester: 6641890
Location: https://acme-staging-v02.api.letsencrypt.org/acme/order/6641890/5930500
Replay-Nonce: YP7xl_k_0GOrJVoWEiSob1MmKxzrpHsPGBU47juw1-c
Expires: Wed, 15 Aug 2018 16:35:57 GMT
Pragma: no-cache
Date: Wed, 15 Aug 2018 16:35:57 GMT
"expires": "2018-08-22T16:35:56.879980679Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-staging-v02.api.letsencrypt.org/acme/authz/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8"
"finalize": "https://acme-staging-v02.api.letsencrypt.org/acme/finalize/6641890/5930500"
2018-08-15 18:35:57,032:DEBUG:acme.client:Storing nonce: YP7xl_k_0GOrJVoWEiSob1MmKxzrpHsPGBU47juw1-c
2018-08-15 18:35:57,032:DEBUG:acme.client:Sending GET request to https://acme-staging-v02.api.letsencrypt.org/acme/authz/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8.
2018-08-15 18:35:57,269:DEBUG:requests.packages.urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "GET /acme/authz/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8 HTTP/1.1" 200 924
2018-08-15 18:35:57,270:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 924
Pragma: no-cache
"identifier": {
"type": "dns",
"expires": "2018-08-22T16:35:56Z",
"challenges": [
"type": "http-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/challenge/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8/159992491",
"token": "kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA"
"type": "dns-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/challenge/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8/159992492",
"token": "rpI6wfDP0ArHzSWsNxr-arOxfRC_ESOIKswiz_1D2yU"
"type": "tls-alpn-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/challenge/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8/159992493",
"token": "a5DG9B6X1I7HzvQeINBw2v2UZLfKo77Apqrj50QB1WA"
2018-08-15 18:35:57,270:INFO:certbot.auth_handler:Performing the following challenges:
2018-08-15 18:35:57,270:INFO:certbot.auth_handler:http-01 challenge for phlinux.ovh
2018-08-15 18:35:57,317:DEBUG:certbot_apache.http_01:Adding a temporary challenge validation Include for name: phlinux.ovh in: /etc/apache2/sites-enabled/phlinux-80.conf
2018-08-15 18:35:57,317:DEBUG:certbot_apache.http_01:writing a pre config file with text:
RewriteEngine on
RewriteRule ^/\.well-known/acme-challenge/([A-Za-z0-9-_=]+)$ /var/lib/letsencrypt/http_challenges/$1 [END]
2018-08-15 18:35:57,317:DEBUG:certbot_apache.http_01:writing a post config file with text:
<Directory /var/lib/letsencrypt/http_challenges>
Require all granted
</Directory>
<Location /.well-known/acme-challenge>
Require all granted
</Location>
2018-08-15 18:35:57,328:DEBUG:certbot.reverter:Creating backup of /etc/apache2/sites-enabled/phlinux-80.conf
2018-08-15 18:36:00,464:INFO:certbot.auth_handler:Waiting for verification...
2018-08-15 18:36:00,465:DEBUG:acme.client:JWS payload:
"keyAuthorization": "kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA.eP1oLvqVTUCVgzcffrXIU0mUEV3QVd8d0Brul7COg9c",
"type": "http-01",
"resource": "challenge"
2018-08-15 18:36:00,466:DEBUG:acme.client:Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/challenge/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8/159992491:
"protected": "eyJub25jZSI6ICJZUDd4bF9rXzBHT3JKVm9XRWlTb2IxTW1LeHpycEhzUEdCVTQ3anV3MS1jIiwgInVybCI6ICJodHRwczovL2FjbWUtc3RhZ2luZy12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsZW5nZS9jREJQenRpbFRyUXV1SG9yX2duLW9oTWRNeUpUdERhNzBTS09JazVlNGw4LzE1OTk5MjQ5MSIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0LzY2NDE4OTAiLCAiYWxnIjogIlJTMjU2In0",
"payload": "ewogICJrZXlBdXRob3JpemF0aW9uIjogImtXRlZtX0x4N3FaTW1qUlNVSEh1UE1IS3dla3pZVFZSWXVUcXpJMExoSUEuZVAxb0x2cVZUVUNWZ3pjZmZyWElVMG1VRVYzUVZkOGQwQnJ1bDdDT2c5YyIsIAogICJ0eXBlIjogImh0dHAtMDEiLCAKICAicmVzb3VyY2UiOiAiY2hhbGxlbmdlIgp9",
"signature": "k123NuqSPEKfIVpL-v8VlGYtqmu9ZfrDoBXhrvH0r3in9aYejWdANEgXsPCcveF4GRXc4N41oXv95Jx0m8zWP0_7O83TDVaqiXQSSR4M9hvQ6-UJbMoIll9LrU2qhHrshG6NnItm-7B3cn3LoCGOWLQBXelPpXRxexI9gcfdUZPqv0alVbiQNCL1Qevbjj25vs2kgcs1XQpWGEBkEFlcLRpYcxlMzmDcBtqk4ar2TPm8Xlm05mLzSRY54SjeJHG9vVxABxj47zMKqX-QNISyHVBA4-DPFj8zHtS4OteXQe4BsK4SRasl2wEqh2duSHSVVanJKHpEywNm8-VKAtq7vg"
2018-08-15 18:36:00,723:DEBUG:requests.packages.urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/challenge/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8/159992491 HTTP/1.1" 200 230
2018-08-15 18:36:00,724:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 230
Link: <https://acme-staging-v02.api.letsencrypt.org/acme/authz/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8>;rel="up"
Location: https://acme-staging-v02.api.letsencrypt.org/acme/challenge/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8/159992491
Replay-Nonce: -p6mxve7ov1jQXKrzIMPXOOF6gx_4_7Y6srxGQlAY74
Expires: Wed, 15 Aug 2018 16:36:00 GMT
Pragma: no-cache
Date: Wed, 15 Aug 2018 16:36:00 GMT
"type": "http-01",
2018-08-15 18:36:00,724:DEBUG:acme.client:Storing nonce: -p6mxve7ov1jQXKrzIMPXOOF6gx_4_7Y6srxGQlAY74
2018-08-15 18:36:03,727:DEBUG:acme.client:Sending GET request to https://acme-staging-v02.api.letsencrypt.org/acme/authz/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8.
2018-08-15 18:36:03,965:DEBUG:requests.packages.urllib3.connectionpool:https://acme-staging-v02.api.letsencrypt.org:443 "GET /acme/authz/cDBPztilTrQuuHor_gn-ohMdMyJTtDa70SKOIk5e4l8 HTTP/1.1" 200 1743
2018-08-15 18:36:03,966:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 1743
Expires: Wed, 15 Aug 2018 16:36:03 GMT
Pragma: no-cache
Date: Wed, 15 Aug 2018 16:36:03 GMT
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://phlinux.ovh/.well-known/acme-challenge/kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA: \"\u003c!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\"\u003e\n\u003chtml\u003e\u003chead\u003e\n\u003ctitle\u003e404 Not Found\u003c/title\u003e\n\u003c/head\u003e\u003cbody\u003e\n\u003ch1\u003eNot Found\u003c/h1\u003e\n\u003cp\"",
"status": 403
"token": "kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA",
"validationRecord": [
"url": "http://phlinux.ovh/.well-known/acme-challenge/kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA",
"hostname": "phlinux.ovh",
"port": "80",
"addressesResolved": [
"88.178.211.92"
"addressUsed": "88.178.211.92"
"type": "dns-01",
2018-08-15 18:36:03,966:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: phlinux.ovh
Detail: Invalid response from http://phlinux.ovh/.well-known/acme-challenge/kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p"
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
2018-08-15 18:36:03,967:DEBUG:certbot.error_handler:Encountered exception:
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 82, in handle_authorizations
self._respond(aauthzrs, resp, best_effort)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 155, in _respond
self._poll_challenges(aauthzrs, chall_update, best_effort)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 226, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. phlinux.ovh (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://phlinux.ovh/.well-known/acme-challenge/kWFVm_Lx7qZMmjRSUHHuPMHKwekzYTVRYuTqzI0LhIA: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
</head><body>
<h1>Not Found</h1>
<p"
2018-08-15 18:36:03,967:DEBUG:certbot.error_handler:Calling registered functions
2018-08-15 18:36:03,967:INFO:certbot.auth_handler:Cleaning up challenges
2018-08-15 18:36:04,178:DEBUG:certbot.log:Exiting abnormally:
File "/opt/eff.org/certbot/venv/bin/letsencrypt", line 11, in <module>
sys.exit(main())
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 1364, in main
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 1254, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 120, in _get_and_save_cert
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py", line 391, in obtain_and_enroll_certificate
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py", line 334, in obtain_certificate
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py", line 370, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
<html><head>
</head><body>
<h1>Not Found</h1>
<p"
