Hi, I have an issue when I want to renew a certificat including 5 domains name.
My domain is: ifdigital.institutfrancais.com
certbot renew --quiet --no-self-upgrade
Challenge failed for domain culturegamer.fr
Challenge failed for domain futurimage.fr
Challenge failed for domain futurlivre.fr
Challenge failed for domain culturevr.fr
Attempting to renew cert (ifdigital.institutfrancais.com) from /etc/letsencrypt/renewal/ifdigital.institutfrancais.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/ifdigital.institutfrancais.com/fullchain.pem (failure)
nginx version: nginx/1.18.0 (Ubuntu)
My hosting provider, if applicable, is: Ubuntu 20.04.2 LTS
no, I have ssh access to configuration of nginx
certbot 0.40.0
So, I have a certificate called "ifdigital.institutfrancais.com" with 5 domains :
Domains: ifdigital.institutfrancais.com culturegamer.fr culturevr.fr futurimage.fr futurlivre.fr
I have a crontab with the following command :
and it always fails since few weeks.
Error is
in letsencrypt.log, I have noticed that the IP address of the failed domains is not the same as my nginx server.
in the old letsencrypt logs, It wasn't like this, the five domains had the same IP.
But I don't have the control of the dns zone file.
Is it realy a problem to have different IP ? Because the dns redirection are OK ; when I'm going to culturegamer.fr, I'm redirecting to the main website ifdigital.institutfrancais.com.
I have also some nginx redirection.
I see this :
redirect.conf :
listen 443 ssl http2;
server_name culturevr.fr culturegamer.fr futurimage.fr futurlivre.fr;
index index.html index.htm;
return 301 https://ifdigital.institutfrancais.com$request_uri;
main.conf
server_name ifdigital.institutfrancais.com;
root /if_digital_prod/project_root/www/web;
Is it a certbot issue, a dns or a nginx misconfiguration ?
Thank you for your help.
