[Issue] Incorrect validation certificate for tls-sni-01 challenge
Hi there,
I have the following issue, I am not able to renew the certificate to below’s domain;
Any suggestion on what the cause might be…
certbot renew
Processing /etc/letsencrypt/renewal/lacozaandam.com.conf
tls-sni-01 challenge for www.lacozaandam.com
tls-sni-01 challenge for lacozaandam.com
Waiting for verification…
Attempting to renew cert (lacozaandam.com) from /etc/letsencrypt/renewal/lacozaandam.com.conf produced an unexpected error: Failed authorization procedure. www.lacozaandam.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 498ed8f18a7521dde07f5cac4f11fc1f.e2590b5b48efc9cbbace2c5e6ee78932.acme.invalid from [2001:888:0:18::117:80]:443. Received 1 certificate(s), first certificate had names “sni-support-required-for-valid-ssl”. Skipping.
Processing /etc/letsencrypt/renewal/lacozaandam.com-0001.conf
Cert not yet due for renewal
/etc/letsencrypt/live/lacozaandam.com-0001/fullchain.pem (skipped)
/etc/letsencrypt/live/lacozaandam.com/fullchain.pem (failure)
    Domain: www.lacozaandam.com
    Detail: Incorrect validation certificate for tls-sni-01 challenge.
    Requested
Server version: Apache/2.4.7 (Ubuntu)
Server built: Sep 18 2017 16:37:54
Server’s Module Magic Number: 20120211:27
Server loaded: APR 1.5.1-dev, APR-UTIL 1.5.3
Compiled using: APR 1.5.1-dev, APR-UTIL 1.5.3
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.5 LTS
Release: 14.04
Codename: trusty
DigitalOcean
Yes
No
Hi @Kreshnik,
It looks to me like you’ve now resolved this problem by removing the AAAA DNS record for your domain. (However, the confusing thing is that your renewed certificate appears to have been issued 2 days ago rather than just now.)
Hi @Kreshnik,
Regarding this conf file, it is attempting to renew a cert containing two domains
lacozaandam.com
www.lacozaandam.com
But, lacozaandam.com is server by Apache web server and www.lacozaandam.com is server by OpenResty web server.
That means that your domains have different ips:
$ dig lacozaandam.com +short
146.185.135.148
$ dig www.lacozaandam.com +short
194.109.6.98
Also, www.lacozaandam.com resolves an IPv6 address 2001:888:0:18::117:80 and this ip would be used by Let's Encrypt to validate your domain as Let's Encrypt prefers IPv6 over IPv4 is both are available.
So, if you are not using IPv6, you should remove the AAAA record for domain www.lacozaandam.com and change its A record to point to your Apache web server 146.185.135.148.
And now the other issue, you have 2 renewal conf files, I suppose because you created a cert for both domains and then created a new one with just one domain or viceversa.
You could check what they are covering using command certbot certificates.
Cheers,
sahsanu
Thanks @sahsanu, I didn’t look carefully enough here after seeing the one recently-renewed cert!
@schoen @sahsanu, first thanks for the switch responses.
@sahsanu when I do a dig on the domains, I do get the following;
146.185.135.148
146.185.135.148
When running certbot certificates I got the following;
Found the following certs:
  Certificate Name: lacozaandam.com
    Domains: www.lacozaandam.com,lacozaandam.com
    Expiry Date: 2017-09-28 21:07:00+00:00 (VALID: 6 days)
    Certificate Path: /etc/letsencrypt/live/lacozaandam.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/lacozaandam.com/privkey.pem
  Certificate Name: lacozaandam.com-0001
    Domains: lacozaandam.com
    Expiry Date: 2017-12-18 09:05:00+00:00 (VALID: 86 days)
    Certificate Path: /etc/letsencrypt/live/lacozaandam.com-0001/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/lacozaandam.com-0001/privkey.pem
Any next steps you guys could suggest…
@Kreshnik,
That is not what your DNS servers say.
$ dig @ns.xs4all.nl lacozaandam.com +short
146.185.135.148
$ dig @ns.xs4all.nl www.lacozaandam.com +short
194.109.6.98
$ dig @ns2.xs4all.nl lacozaandam.com +short
146.185.135.148
$ dig @ns2.xs4all.nl www.lacozaandam.com +short
194.109.6.98
Well, you have 2 certificates,
1.- lacozaandam.com that covers both domains (with and without www) and will expire in 6 days.
2.- lacozaandam.com-0001 that covers only the domain without www and will expire in 86 days.
Which one you want to use?. If you want a certificate for both domains (certificate 1) then you should solve your DNS issues with www domain. If you only want to use the certificate for the domain without www then use the certificate 2 (you are already using it) and delete the certificate 1.
Thank you very much @sahsanu, this descriptive answers makes it much easier to solve the issue.
P.s. I will probably go with 1 (Solving DNS issue)
Thanks!
@Kreshnik, you are welcome.
Remember that you need to solve 2 issues with www domain. the incorrect IPv4 address and the IPv6 address, if you won’t use it, remove the AAAA record or Let’s Encrypt will try to validate your domain with this IPv6 address and will fail.
