Issue generating cert
Hello! i'm having issues generating the cert
My domain is: mvt.ar
I'm trying to generate
I ran this command: using swag:
swag:
    image: lscr.io/linuxserver/swag
    container_name: swag
    cap_add:
      - NET_ADMIN
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=America/Argentina/Buenos_Aires
      - URL=mvt.ar
      - VALIDATION=dns
      - SUBDOMAINS=wildcard
      - DNSPLUGIN=cloudflare
      - DOCKER_MODS=linuxserver/mods:swag-auto-proxy|linuxserver/mods:universal-docker|linuxserver/mods:universal-cloudflared
      - DOCKER_HOST=dockerproxy
      - CF_ZONE_ID=cloudflare_zone_id
      - CF_ACCOUNT_ID=cloudflare_acc_id
      - CF_API_TOKEN=cloudflare_api_token
      - CF_TUNNEL_NAME=mvt.ar
      - CF_TUNNEL_PASSWORD=secure_passwd
      - FILE__CF_TUNNEL_CONFIG=/config/tunnelconfig.yml
    extra_hosts:
      - mvt.ar:127.0.0.1
    volumes:
      - /home/me/docker/aptalca/appdata/swag:/config
    restart: unless-stopped
dns validation via cloudflare plugin is selected
Generating new certificate
Requesting a certificate for *.mvt.ar and mvt.ar
Unsafe permissions on credentials configuration file: /config/dns-conf/cloudflare.ini
Unable to determine zone_id for mvt.ar using zone names: ['mvt.ar', 'ar']. The error from Cloudflare was: 0 confused info - both key and token defined.
ERROR: Cert does not exist! Please see the validation error above. Make sure you entered correct credentials into the /config/dns-conf/cloudflare.ini file.
API Token has:
  • All accounts - Cloudflare Tunnel:Edit
  • All zones - Zone:Edit, DNS:Edit
Cloudflare is pointing to my server and ports 80 and 443 are open. Proxy status was disabled on CF
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.32.0
Any idea on why i'm getting the following error ? Thanks in advance!
Hello @acel, welcome to the Let's Encrypt community. :slightly_smiling_face:
Let's Debug is showing 2 WARNINGs for DNS-01 Challenge.
Here is a list of issued certificates, one, crt.sh | mvt.ar, issued on 2023-01-10.
Unrelated, as:
I think the instructions are spot on:
woww! How could I have missed that!!
Thank you very much for the help!! Finally, I was able to generate it! :raised_hands: :heart:
