Is it possible to change my site’s encryption to RSA 4096 or Elliptic Curve? If so, how? It is currently at RSA 2048 (default).
Basically, YES.
But the “how” depends on the particular ACME client.
Thanks for the response. I am using Azure for my website and installed the certificate with this extension: https://github.com/sjkp/letsencrypt-siteextension
Their readme doesn’t mention it, they probably haven’t considered it, but you should ask them. (or consider changing client yourself, but that can be difficult if you are invested in this one)
Well, their code does suggest a "range" of key sizes:
