Iphone 5 not renewing certificate
hello,
i dont know where the problem is
LE is working fine, certs get renewed etc etc.
But every time the old certificate is renewed im getting complains from apple users that the have prolem with there emails.
The certificate is renewed after 60 days.
The problem starts when the old certificate expires (so 30 days later)
The server has allready installed the new certificate fine. So it is a problem with iphone/apple
Looks like they store the certificate and dont renewed them?
Anyone else have this problem?
Hi @Steffan,
Please let us know the specific domain name, and ideally also a screenshot of the error message people see on the iPhone. There are so many different reasons that a certificate can be misconfigured
https://badssl.com/
so it would be really helpful to be able to see the specific error here.
The problem here is that there is nothing wrong with the certificate
tested it with tlscheck.com
only apple has problem with it after the 3 months.
All other moments there is no problems
so the iphone (5) imac is not taking the new certificate but is keeping the old certificate and after that email cant be collected with ssl (mail.tofmail.eu) is the mailserver name.
I dont have screenshots but the message was
identification of ‘mail.tofmail.eu’ cant be checked
check of SSL-server ‘mail.tofmail.eu’ not possible
It looks like your web server serves the intermediate cert as it should, but your IMAP server doesn’t. When I do openssl s_client -connect mail.tofmail.eu:993, it only serves the leaf cert.
im using this configuration in postfix
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_tls_CAfile = /etc/letsencrypt/live/mail.tofmail.eu/fullchain.pem
smtpd_tls_CApath = /etc/letsencrypt/live/mail.tofmail.eu
lrwxrwxrwx 1 root root 46 Oct 7 2016 smtpd.cert -> /etc/letsencrypt/live/mail.tofmail.eu/cert.pem
lrwxrwxrwx 1 root root 49 Oct 7 2016 smtpd.key -> /etc/letsencrypt/live/mail.tofmail.eu/privkey.pem
and in
/etc/dovecot/conf.d/10-ssl.conf
ssl_cert = </etc/letsencrypt/live/mail.tofmail.eu/cert.pem
ssl_key = <//etc/letsencrypt/live/mail.tofmail.eu/privkey.pem
So what do i have to add?
i changed ssl.conf to
ssl_cert = </etc/letsencrypt/live/mail.tofmail.eu/fullchain.pem
then im getting Verify return code: 20 (unable to get local issuer certificate)
but that choeld be fine i think reading another post?
but is that a fix for the iphone problems?
I think it should be, at least on the IMAP side. I haven't checked SMTP though.
well i will see then in 2 months when the certificate expire :slight_smile:
For Postfix, smtpd_tls_cert_file should be the path to fullchain.pem and smtpd_tls_key_file should be pointing to privkey.pem. the tls_CA parameters should not be using Let’s Encrypt items, they are used to verify external server certificates.
For Dovecot, ssl_cert should be pointed to fullchain.pem and ssl_key to privkey.pem.
Your problem looks to be that you’re not sending the full chain with Dovecot, and it seems like you’re not sending the LE certs with Postfix at all.
im sorry you lost me.
What do i have to change acording to you.
dovecot is now pointing to fullchain.pem
if i do
openssl s_client -showcerts -connect mail.tofmail.eu:993
im getting lets encrypt returned
you say “Your problem looks to be that you’re not sending the full chain with Dovecot, and it seems like you’re not sending the LE certs with Postfix at all.”
what do you want me to change:
smtpd_tls_cert_file = /etc/letsencrypt/live/mail.tofmail.eu/cert.pem
smtpd_tls_key_file = /etc/letsencrypt/live/mail.tofmail.eu/privkey.pem
I can confirm your Dovecot configuration looks good now. I’m getting the full certificate chain on connect.
Remove the smtpd_tls_CA* lines. Those are used when Postfix needs to validate a remote server’s certificate. Change smtpd_tls_cert_file to point to fullchain.pem. That should get you serving all the correct certificate chains to the clients. As long as those clients support the DST Root, they will work fine.
Keep in mind that if users are connecting using a name that is not in the certificate, they will get a warning because of the name mismatch.
thanxs hopfely that wil fix the iphone problems
are you restarting Dovecot after updating the certificate?
If I remember correctly Dovecot reads the TLS related files only once on startup before dropping root privileges, so if you in the meantime update your certs without restarting the server, it will continue to use the old ones.
But in this case the issue ought to affect all your users, not just the iPhone/Apple ones, so I may also be misjudging the problem.
Yes it is restarted.
Only iphone costumers
Don’t know how many clients are using iphones.
Can you perhaps get any more information about the configuration that the iPhone users use, and the error message that they get when they try to connect?
multiple users with iphone 5
i dont know if all users are a iphone 5.
The error message that they recieve is:
(translated from dutch to englisch)
Identification of mail.tofmail.eu cant be checked
Checking of SSL-server mail.tofmail.eu not possible
from one user i had screenshots
They are using the servername as hostname.
Has SSL enabled
And is using port 587 for outgoing email.
Hi @Steffan,
I don't use Postfix nor iPhone so I don't know what are the configuration options you have but something you should check:
Your smtp server listening on port 587 is not starting a TLS negotiation directly, it starts the conversation in plain text and it offers start a TLS communication if the client uses STARTTLS.
I mean, if you try to connect with a client using TLS directly you get this "error":
 $ openssl s_client -connect mail.tofmail.eu:587
CONNECTED(00000003)
6870300:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:787:
no peer certificate available
SSL handshake has read 7 bytes and written 517 bytes
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
If the client supports STARTTLS the there is no problem at all:
$ openssl s_client -starttls smtp -connect mail.tofmail.eu:587
CONNECTED(00000003)
depth=1 C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
verify error:num=20:unable to get local issuer certificate
verify return:0
Certificate chain
 0 s:/CN=mail.tofmail.eu
   i:/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
 1 s:/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=/CN=mail.tofmail.eu
issuer=/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
SSL handshake has read 3571 bytes and written 742 bytes
New, TLSv1/SSLv3, Cipher is DHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : DHE-RSA-AES256-GCM-SHA384
    Session-ID: 3FAA4D41FE79556D43FFB3A7CAEB42242BD9CA55EB67FE24FD5FFC2895C6B72E
    Session-ID-ctx:
    Master-Key: F95DE63A8A2CBD60E021D37A472E1C137F9E121175C52D3737FE858D03065655EFF07F396F36E257A9E5363F84B920CA
    Key-Arg   : None
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 3600 (seconds)
    TLS session ticket:
    0000 - fb 5b 41 0a e3 e5 29 63-e2 28 a9 01 c7 78 bd 9c   .[A...)c.(...x..
    0010 - eb 58 5c a3 23 eb a7 85-59 65 10 f3 d0 50 27 6d   .X\.#...Ye...P'm
    0020 - 60 25 bf 93 3c ab 1f 13-50 07 0f eb ac aa 75 21   `%..<...P.....u!
    0030 - 76 0e 92 c0 9b ee 7a 16-00 09 b8 14 53 34 1c 5b   v.....z.....S4.[
    0040 - 40 02 c2 ee 7e 2f f3 78-5f ba cd 52 99 9d b3 f9   @...~/.x_..R....
    0050 - 58 de 6a 3d c5 81 b8 57-70 49 09 c6 59 38 90 cb   X.j=...WpI..Y8..
    0060 - a4 e0 2a 90 14 85 52 7c-14 5e 80 e5 34 f4 c2 d6   ..*...R|.^..4...
    0070 - 9d 55 c9 fd 5c b6 01 e2-11 10 4b fb c2 94 86 b7   .U..\.....K.....
    0080 - 01 f5 b6 92 5b 72 6a 06-91 3b b4 ae 65 96 35 c0   ....[rj..;..e.5.
    0090 - a0 79 0d 40 be bf f3 12-01 08 3f 37 25 6e 81 0d   .y.@......?7%n..
    Start Time: 1503391171
    Timeout   : 300 (sec)
250 DSN
ehlo test.com
250-mail.tofmail.eu
250-PIPELINING
250-SIZE
250-VRFY
250-ETRN
250-AUTH PLAIN LOGIN
250-AUTH=PLAIN LOGIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
quit
221 2.0.0 Bye
closed
That said, I don't know how the iOS mail app is trying to connect to your server when you select SSL and port 587, don't know if it is smart enought to select STARTTLS if it detects that the communication to that port is unencrypted. So, maybe you could ask the customer to try to activate SSL and use port 25 just in case the mail client can detect it and ask the user if he/she wants to use STARTTLS.
Cheers,
sahsanu
I know mailprogramms are abusing the names ssl, tls and starttls.
The mailaccounts normaly works
only on the days the old ssl expire this problems start to turn up
so it cant be the configuration of the mailclient.
When te user switch the hostname and after that change it back the cert is getting reread bij the iphone and it works again.
Its very strang, and i also dont own a iphone to test :frowning:
If you’re still having issues, I do have an iPad I can use to test. As it’ll require an account temporarily so it can be configured on the device, you can send me a PM if you would like.
Please keep in mind the usual warnings about sending account information to strangers on the internet.
Just some findings… may be completely unrelated to your problem and it’s solution - but I thought I would mention them.
iPhone email connections use 587 and 993.
Checking on
mail.tofmail.eu:587
mail.tofmail.eu:993
found these ciphersuites (there may be others):
DHE-RSA-AES256-GCM-SHA384 Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-AES128-GCM-SHA256 Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-AES256-SHA256 Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-AES128-SHA256 Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-AES256-SHA Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-CAMELLIA256-SHA Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-AES128-SHA Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-SEED-SHA Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
DHE-RSA-CAMELLIA128-SHA Peer signing digest: SHA512 Server Temp Key: DH, 1024 bits
AES256-GCM-SHA384
AES128-GCM-SHA256
AES256-SHA256
AES128-SHA256
AES256-SHA
CAMELLIA256-SHA
AES128-SHA
SEED-SHA
CAMELLIA128-SHA
IDEA-CBC-SHA
EDH-RSA-DES-CBC3-SHA
DES-CBC3-SHA
Using ciphers with 1024 bit DH primes as preferred can cause problems on systems that require higher DH primes as that parameter is NOT negotiated between client and server.
iOS 10 no longer supports DHE ciphers, so that should not be part of the problem with an updated iPhone 5.
(iOS 8 however does support DHE ciphers)
If at all possible, I would add ECDHE ciphers and prefer them on the list.
And remove any outdated or unused ciphers and protocols - to avoid things like downgrade attacks.
