Invalid response from .well-known when running certbot
My domain is: gencyberbook.com
http-01 challenge for gencyberbook.com
Challenge failed for domain gencyberbook.com
My web server is (include version): Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
I have been trying to fix this issue for days and still no results. I have checked that port 80 and 443 are allowed in the security groups for the AWS EC2 instance and also checked that the DNS records are correct. Please help!
Hi @nathan-jimin,
What's the output of:
sudo apachectl -t -D DUMP_VHOSTS
Hi @_az!
Here is the output
ubuntu@gencyberbook:/etc/apache2/sites-available$ sudo apache2ctl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:80 is a NameVirtualHost
default server gencyberbook.com (/etc/apache2/sites-enabled/000-default.conf:2)
port 80 namevhost gencyberbook.com (/etc/apache2/sites-enabled/000-default.conf:2)
port 80 namevhost gencyberbook.com (/etc/apache2/sites-enabled/ossn.conf:1)
alias www.gencyberbook.com
Try add a dummy ServerName in this VirtualHost, like ServerName example.com.
I should also mention that this relates to a bug we fixed very recently in Certbot 1.17.0:
  • The Apache authenticator now always configures virtual hosts which do not have an explicit ServerName . This should make it work more reliably with the default Apache configuration in Debian-based environments.
... so if you install Certbot using our snap or pip instructions, it should work without the workaround.
Thank you so much! The certificate is now installed, but it seems I am going to do some other troubleshooting for apache2 now. This does fix my problem though!
