Invalid response from ... 404 Not Found
Apologies but I tried following other similar topics with no success: - very new to Ubuntu/lets encrypt
running command:
sudo letsencrypt certonly -a webroot --webroot-path=/var/www/csda -d csda.co.za -d www.csda.co.za
server: Ubuntu 16.04 / NGINX
domains are active and working:
Is it possible I don't have the correct rights? Gave my user -aG sudo access. But unable to create directories under this user.
Error stack:
Failed authorization procedure. csda.co.za (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://csda.co.za/.well-known/acme-challenge/1KHcWbGAA_jIkfpYJc08ytwKbq6jh94eENK-rXwL4AM: "<html>
<head><title>404 Not Found</title></head>
<body bgcolor="white">
<center><h1>404 Not Found</h1></center>
<hr><center>", www.csda.co.za (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.csda.co.za/.well-known/acme-challenge/4QsrxRbj1U9wmuT1FXhpMYTxlbE5GZ8k9XHfnjOp8n4: "<html>
<hr><center>"
   Domain: csda.co.za
   Type:   unauthorized
   Detail: Invalid response from http://csda.co.za/.well-known/acme-
   <hr><center>"
   Domain: www.csda.co.za
   Type:   unauthorized
   Detail: Invalid response from http://www.csda.co.za/.well-known
   "<html>
   <hr><center>"
I gave my user the following right but still not working
sudo chown -R anton:anton /var/www
Can you put a test text file containing a simple word in /var/www/csda/.well-known/acme-challenge and try to access it by surfing to it?
For example:
echo "It works!" > /var/www/csda/.well-known/acme-challenge/test
and surf to http://csda.co.za/.well-known/acme-challenge/test
Thanks Osiris, that was rather dumb of me. I’m using ASP.Net Core so there is something else that is disallowing that location.
I’ll figure it out from here…
