Invalid Response Errors
I'm only assuming the . is reference for NGINX directory.
I don't like assumptions.
Can you place a test text file there and see if it can be reached from the Internet?
Also, there are 162 posts here...
This is vague and requires one to scroll back [way back]:
Please be more detailed in your posts [even if it sounds like you are repeating yourself - don't worry].
So when I turned everything off and only had the "ia.midwestrp.net" domain loading, I was able to reach the hello.txt file we created, no issues. However, now that I reverted everything back, it is no longer accessible.
So I was able to reach the test file at "ia.midwestrp.net/hello2.txt" when it was only that domain loaded.
I tore that full config apart - line by line - I can't find the problem.
That really should just be
The use of ~ indicates a regular expression and changes the priority of location block selection. In your case it overrides the location for the /.well-known/acme-challenge
See docs (link here)
I don't think that explains all the odd things seen here but it's one thing anyway.
let's see which process binds on port 80. maybe find something else
in powershell
Get-Process -Id (Get-NetTCPConnection -LocalPort 80).OwningProcess
and it's sweeping trash under the rug approch, but can it look like short downtown doesn't matter can we just kill entire nginx and run in standalone mod?
This was it!!!!!
The man deserves a pizza and beer!!!!!
