Good question! I have no idea. I renamed it to "2" on the new code file.
It only appears in the file [from post #15]:
C:\WEB_SERVERS\NGINX/conf/mwrp/midwestrp.net.conf
[which you were supposed to remove that block from it]
So, does that block still exist in that file?
Are you making changes in a copy of the real system? [LOL]
[in a parallel dimension ...]
Then recheck through the outout of: nginx -T
For the occurance of "ia.access.log
Never got the answer to:
Sorry. Not to my knowledge.
Just reviewed ... it is not mentioned anywhere...
C:\WEB_SERVERS\NGINX>nginx -T
nginx: the configuration file C:\WEB_SERVERS\NGINX/conf/nginx.conf syntax is ok
nginx: configuration file C:\WEB_SERVERS\NGINX/conf/nginx.conf test is successful
# configuration file C:\WEB_SERVERS\NGINX/conf/nginx.conf:
#user nobody;
worker_processes auto;
#error_log logs/error.log;
#error_log logs/error.log notice;
#error_log logs/error.log info;
pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
log_format main '$remote_addr - $ssl_server_name $remote_user [$time_local] '
'"$request" ($status - ${request_length}b->${body_bytes_sent}b) '
'in ${request_time}s "$request_body" '
'"$http_referer" "$http_user_agent" ';
log_format ia '$remote_addr - $ssl_server_name $remote_user [$time_local]'
'"$request" ($status - ${request_length}b->${body_bytes_sent}b)'
'in ${request_time}s'
'"$http_referer" "$http_user_agent"';
#access_log logs/access.log main;
server_tokens off;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
gzip on;
server_names_hash_bucket_size 64;
keepalive_timeout 65;
include "mwrp/ia.midwestrp.net.conf";
include "localhost.conf";
include "mwrp/midwestrp.net.conf";
include "mwrp/mwrp.app.conf";
include "mwrp/api.mwrp.app.conf";
include "mwrp/logger.mwrp.app.conf";
include "mwrp/portainer.mwrp.app.conf";
include "mwrp/clickup.mwrp.app.conf";
include "mwrp/map.mwrp.app.conf";
listen 80;
server_name shortener.mwrp.app;
access_log logs/shortener.access.log main;
set_real_ip_from 103.21.244.0/22;
set_real_ip_from 103.22.200.0/22;
set_real_ip_from 103.31.4.0/22;
set_real_ip_from 104.16.0.0/13;
set_real_ip_from 104.24.0.0/14;
set_real_ip_from 108.162.192.0/18;
set_real_ip_from 131.0.72.0/22;
set_real_ip_from 141.101.64.0/18;
set_real_ip_from 162.158.0.0/15;
set_real_ip_from 172.64.0.0/13;
set_real_ip_from 173.245.48.0/20;
set_real_ip_from 188.114.96.0/20;
set_real_ip_from 190.93.240.0/20;
set_real_ip_from 197.234.240.0/22;
set_real_ip_from 198.41.128.0/17;
set_real_ip_from 2400:cb00::/32;
set_real_ip_from 2606:4700::/32;
set_real_ip_from 2803:f800::/32;
set_real_ip_from 2405:b500::/32;
set_real_ip_from 2405:8100::/32;
set_real_ip_from 2c0f:f248::/32;
set_real_ip_from 2a06:98c0::/29;
real_ip_header CF-Connecting-IP;
location ~ / {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-For $remote_addr;
proxy_set_header X-Forwarded-Host $remote_addr;
proxy_pass http://127.0.0.1:4000;
allow all;
listen 443 ssl;
ssl_certificate certs/mwrp.crt;
ssl_certificate_key certs/mwrp.key;
ssl_session_cache shared:SSL:1m;
ssl_session_timeout 5m;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
access_log logs/shortener-ssl.access.log main;
location ~ / {
allow all;
listen 80;
server_name loi.mwrp.app;
access_log logs/loi.mwrp.app.access.log main;
location ~ / {
proxy_pass http://127.0.0.1:5683;
listen 443 ssl;
location ~ / {
listen 80;
server_name dev-portals.mwrp.app;
access_log logs/portals.access.log main;
location ~ / {
proxy_pass http://127.0.0.1:5692;
listen 443 ssl;
access_log logs/portals-ssl.access.log main;
location ~ / {
# configuration file C:\WEB_SERVERS\NGINX/conf/mime.types:
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/svg+xml svg svgz;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.oasis.opendocument.graphics odg;
application/vnd.oasis.opendocument.presentation odp;
application/vnd.oasis.opendocument.spreadsheet ods;
application/vnd.oasis.opendocument.text odt;
application/vnd.openxmlformats-officedocument.presentationml.presentation
pptx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
xlsx;
application/vnd.openxmlformats-officedocument.wordprocessingml.document
docx;
application/vnd.wap.wmlc wmlc;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/ia.midwestrp.net.conf:
listen 80;
server_name ia.midwestrp.net;
access_log logs/ia2.access.log ia;
error_log logs/ia2.error.log warn;
root C:/WEB_SERVERS/nginx/html/;
access_log testing.log;
error_log testing.log;
location ~ / {
#root ./html/ia.midwestrp.net/;
proxy_pass http://127.0.0.1:5681;
allow all;
listen 443 ssl;
ssl_certificate certs/mw.crt;
ssl_certificate_key certs/mw.key;
access_log logs/ia-ssl2.access.log ia;
location ~ / {
allow all;
# configuration file C:\WEB_SERVERS\NGINX/conf/localhost.conf:
listen 80;
server_name localhost;
access_log logs/host.access.log main;
location ~ / {
allow 127.0.0.1;
deny all;
listen 443 ssl;
access_log logs/host-ssl.access.log main;
location ~ / {
allow 127.0.0.1;
deny all;
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/midwestrp.net.conf:
# rewrite ^ http://community.midwestrp.net$request_uri? permanent;
listen 80;
server_name midwestrp.net;
access_log logs/mwrp.access.log main;
location ~ / {
#root ./html/www.midwestrp.net/;
rewrite ^/$ https://community.midwestrp.net redirect;
allow all;
listen 443 ssl;
access_log logs/mwrp-ssl.access.log main;
location ~ / {
allow all;
listen 80;
server_name www.midwestrp.net;
location ~ / {
allow all;
listen 443 ssl;
location ~ / {
allow all;
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/mwrp.app.conf:
listen 80;
server_name mwrp.app;
access_log logs/dev.access.log main;
location ~ / {
allow all;
listen 443 ssl;
access_log logs/dev-ssl.access.log main;
location ~ / {
allow all;
listen 80;
server_name mwrp.dev;
location ~ / {
allow all;
listen 443 ssl;
location ~ / {
allow all;
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/api.mwrp.app.conf:
listen 80;
server_name api.mwrp.app;
access_log logs/api.access.log main;
location ~ / {
proxy_pass http://127.0.0.1:4004;
listen 443 ssl;
access_log logs/api-ssl.access.log main;
location ~ / {
listen 80;
server_name api-assistant-internal.mwrp.app;
access_log logs/api-assistant-internal.access.log main;
location ~ / {
proxy_pass http://127.0.0.1:4848;
listen 443 ssl;
access_log logs/api-assistant-internal-ssl.access.log main;
location ~ / {
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/logger.mwrp.app.conf:
listen 80;
server_name logger.mwrp.app;
access_log logs/logger.access.log main;
location ~ / {
proxy_pass http://127.0.0.1:4002;
allow 127.0.0.1;
allow 147.135.105.106;
deny all;
listen 443 ssl;
access_log logs/logger-ssl.access.log main;
location ~ / {
allow 127.0.0.1;
deny all;
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/portainer.mwrp.app.conf:
listen 80;
server_name manage.mwrp.app;
access_log logs/manage.access.log main;
location ~ / {
proxy_pass https://127.0.0.1:9443;
listen 443 ssl;
access_log logs/manage-ssl.access.log main;
location ~ / {
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/clickup.mwrp.app.conf:
listen 80;
server_name clickup.mwrp.app;
access_log logs/clickup.access.log main;
location ~ / {
proxy_pass http://127.0.0.1:5682;
allow all;
listen 443 ssl;
access_log logs/clickup-ssl.access.log main;
location ~ / {
allow all;
# configuration file C:\WEB_SERVERS\NGINX/conf/mwrp/map.mwrp.app.conf:
listen 80;
server_name livemap.mwrp.app;
access_log logs/livemap.access.log main;
location ~ / {
rewrite ^/$ https://map.mwrp.app redirect;
allow all;
listen 443 ssl;
access_log logs/livemap-ssl.access.log main;
location ~ / {
allow all;
C:\WEB_SERVERS\NGINX>```
I think I'm going to throw in the [sweaty/blood-soaked] towel ...
It beat me [to a pulp] !
Best of luck to you.
Cheers from Miami
I can't thank you enough for the time you've invested in this. I really wish I knew what is happening. I'll keep looking.
thank you!
Can any of this be a firewall issue?
No. Wouldn't explain the odd stuff.
Could you have multiple nginx running under different Windows accounts (yet maybe sharing some of the nginx config)?
I do not believe so, however, I will reboot to ensure. The only user logged in is mine (Admin).
Here is the ia2.error.log that we created.
@rg305
2023/01/13 22:40:53 [error] 7024#18132: *2 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "ia.midwestrp.net", referrer: "https://ia.midwestrp.net/"
2023/01/13 22:40:54 [error] 7024#18132: *2 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "ia.midwestrp.net", referrer: "https://ia.midwestrp.net/"
2023/01/13 22:40:55 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:41:10 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:41:25 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:41:40 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:41:55 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:42:10 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:42:25 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:42:40 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:42:55 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"
2023/01/13 22:42:56 [error] 7024#18132: *32 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /hello2.txt HTTP/1.1", upstream: "http://127.0.0.1:5681/hello2.txt", host: "ia.midwestrp.net"
2023/01/13 22:42:57 [error] 7024#18132: *34 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 101.68.211.3, server: ia.midwestrp.net, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:5681/", host: "147.135.105.106:80"
2023/01/13 22:42:58 [error] 7024#18132: *32 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "ia.midwestrp.net", referrer: "http://ia.midwestrp.net/hello2.txt"
2023/01/13 22:42:58 [error] 7024#18132: *38 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:5681/", host: "ia.midwestrp.net"
2023/01/13 22:42:59 [error] 7024#18132: *40 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 101.68.211.3, server: ia.midwestrp.net, request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:5681/", host: "147.135.105.106:80"
2023/01/13 22:42:59 [error] 7024#18132: *38 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "ia.midwestrp.net", referrer: "https://ia.midwestrp.net/"
2023/01/13 22:43:00 [error] 7024#18132: *32 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /hello2.txt HTTP/1.1", upstream: "http://127.0.0.1:5681/hello2.txt", host: "ia.midwestrp.net"
2023/01/13 22:43:00 [error] 7024#18132: *44 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 101.68.211.3, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "147.135.105.106:80"
2023/01/13 22:43:00 [error] 7024#18132: *38 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "ia.midwestrp.net", referrer: "https://ia.midwestrp.net/"
2023/01/13 22:43:01 [error] 7024#18132: *32 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 63.225.195.213, server: ia.midwestrp.net, request: "GET /favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5681/favicon.ico", host: "ia.midwestrp.net", referrer: "http://ia.midwestrp.net/hello2.txt"
2023/01/13 22:43:02 [error] 7024#18132: *48 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 101.68.211.3, server: ia.midwestrp.net, request: "GET /robots.txt HTTP/1.1", upstream: "http://127.0.0.1:5681/robots.txt", host: "147.135.105.106:80"
2023/01/13 22:43:10 [error] 7024#18132: *9 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 51.161.33.235, server: ia.midwestrp.net, request: "GET /metrics HTTP/1.1", upstream: "http://127.0.0.1:5681/metrics", host: "147.135.105.106:80"```
Rebooted, and still same problems.
With these entries in that log:
it would seem that it is coming from the default HTTP server block.
And that's my server ...
I'm really lost ...
I've been trying to research everything and I can't seem to find anything to assist.
I'd tidy things up a bit...
There are server blocks in the main config file:
I'd move them to their own file(s) and then include them back in.
I'd also do the same for those large "set_real_ip
" sections.
Anything that repeats exactly in many places, do the same.
Sounds good. Let me get going on this. Thank you.
Hi Everyone,
Here is an update.
After reviewing everything, I discovered that "midwestrp.net" and "www.midwestrp.net" was loaded into port 80 and 443. Knowing certbot can only do those ports, I decided to remove all domains and just load in "ia.midwestrp.net" so it would load and use port 80 and 443.
That being said, I loaded only that domain into the file and I confirmed it was the only domain loading into port 80 and 443. Here is the nginx -T print out:
#user nobody;
pid logs/nginx.pid;
events {
http {
include mime.types;
server_tokens off;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
gzip on;
#include "localhost.conf";
#include "mwrp/midwestrp.net.conf";
#include "mwrp/mwrp.app.conf";
#include "mwrp/api.mwrp.app.conf";
#include "mwrp/logger.mwrp.app.conf";
#include "mwrp/portainer.mwrp.app.conf";
#include "mwrp/clickup.mwrp.app.conf";
#include "mwrp/map.mwrp.app.conf";
types {
text/css css;
text/xml xml;
image/gif gif;
text/mathml mml;
text/plain txt;
image/png png;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
pptx;
xlsx;
docx;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
video/mp2t ts;
video/mp4 mp4;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-wmv wmv;
listen 80;
location ~ / {
#proxy_pass http://127.0.0.1:5681;
allow all;
listen 443 ssl;
location ~ / {
allow all;
I then attempt to do the the certbot certonly command and still receive the following error:
Domain: ia.midwestrp.net
Detail: 147.135.105.106: Invalid response from http://ia.midwestrp.net/.well-known/acme-challenge/15O4QOkcXAxSHoSgBrkKu2EFwmXlQy9HGbCh0_0o0xw: 404
Any ideas?
Thank you.
Is there supposed to be a dot before html?
