Interpreting Post-Hook Output from Bitnami Server with Certbot
My domain is: www.any-app-dictation.com
I ran this command: ./certbot-auto renew --dry-run --pre-hook “sudo /opt/bitnami/ctlscript.sh stop” --post-hook “sudo /opt/bitnami/ctlscript.sh start”
It produced this output: everything went fine but then it ended with the post-hook: sudo /opt/bitnami/ctlscript.sh start - after that nothing ever happened again. I never saw my prompt anymore. BTW: I’m using putty to access my VM that is running a Bitnami LAMP
My web server is (include version): Bitnami LAMP (latest)
The operating system my web server runs on is (include version): Linux
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
Some questions:
  1. List item
Why does it never showed the command prompt anymore after successfully renewing the certificate?
  1. List item
What is the right command, to see until when the current certificate is still valid?
  1. List item
Is it normal, that the folder /live/ does not “update” it’s date when a successful renewal was done?
  1. List item
Can someone point me to a good tutorial, so the certificate will be renewed automatically, e.g. by a cron job?
Thank you very much.
A1. unknown to me - try checking the LE logs for more details.
A2. certbot certificates
Hi rg305
Many thanks for the information. I was now able to find and access my log file with:
$ sudo -i
$ cd /var/log/letsencrypt/
$ nano letsencrypt.log
Now the last lines in that log file are:
2017-09-04 09:00:29,838:DEBUG:certbot.storage:Writing new private key to /etc/letsencrypt/archive/www.myhomepage.com/privkey2.pem.
2017-09-04 09:00:29,838:DEBUG:certbot.storage:Writing certificate to /etc/letsencrypt/archive/www.myhomepage.com/cert2.pem.
2017-09-04 09:00:29,838:DEBUG:certbot.storage:Writing chain to /etc/letsencrypt/archive/www.myhomepage.com/chain2.pem.
2017-09-04 09:00:29,838:DEBUG:certbot.storage:Writing full chain to /etc/letsencrypt/archive/www.myhomepage.com/fullchain2.pem.
2017-09-04 09:00:31,344:DEBUG:certbot.storage:Writing new config /etc/letsencrypt/renewal/www.myhomepage.com.conf.new.
2017-09-04 09:00:31,346:DEBUG:certbot.renewal:no renewal failures
2017-09-04 09:00:31,346:INFO:certbot.hooks:Running post-hook command: sudo /opt/bitnami/ctlscript.sh start
2017-09-10 19:21:44,635:INFO:certbot.hooks:Output from sudo:
2017-09-04T09:00:31.461119Z mysqld_safe Logging to '/opt/bitnami/mysql/data/mysqld.log'.
2017-09-04T09:00:31.478514Z mysqld_safe Starting mysqld.bin daemon with databases from /opt/bitnami/mysql/data
/opt/bitnami/mysql/scripts/ctl.sh : mysql  started at port 3306
/opt/bitnami/php/scripts/ctl.sh : php-fpm started
/opt/bitnami/apache2/scripts/ctl.sh : httpd started at port 80
2017-09-10T19:21:44.634224Z mysqld_safe mysqld from pid file /opt/bitnami/mysql/data/mysqld.pid ended
2017-09-10 19:21:44,635:ERROR:certbot.hooks:Error output from sudo:
AH00548: NameVirtualHost has no effect and will be removed in the next release /opt/bitnami/apps/aadictation/conf/httpd-vhosts.conf:1
Syntax OK
Unfortunaly that doesn't tell me anything. What could be wrong? Why am I not seeing the prompt anymore after the update process?
Any help very welcome.
Thanks.
Probably that you shouldn’t be using NameVirtualHost directives in your httpd conf files. Looks like it’s confusing Certbot as it tries to parse these files. I’m not that intimately familiar with Apache, though.
Hi jared.m
thank you for the fast reply. But that is a message I always get when I start or restart my apache server. It has no effect whatsoever and it’s shown to me ever since the server was installed. I never changed anything in this direction.
In other words I can’t belive that I should change the core of the server in any way to get letsencrypt functioning correctly. I would rather leave the core system and server as it is and not start to change it for this issue.
Any other ideas?
Many thanks.
Try adding
-v
or
-vv
for added verbose output in the logs
If you look at the results
A) You obtained the certificates
B) You started the mysql server
C) Starting the apache server gave you warnings
Syntax OK
AH00548: NameVirtualHost has no effect and will be removed in the next release /opt/bitnami/apps/aadictation/conf/httpd-vhosts.conf:100:
Work with bitnami forums/support for this issue
Your site is working fine with a certificate valid to 3rd December 2017
Andrei
Hi Andrei,
many thanks!!! That was a great hint however it doesn't seem to be a solution yet. I quickly googled those lines and came up with this solution:
Remove of NameVirtualHost
In the file
I discovered two lines:
NameVirtualHost: *80
and
NameVirtualhost: *443
and removed them. Then I started the dry run command, as seen in my original post, again and the log file now it looks like this:
2017-09-29 10:31:54,468:DEBUG:certbot.renewal:Dry run: skipping updating lineage at /etc/letsencrypt/live/www.myhomepage.com
2017-09-29 10:31:54,469:DEBUG:certbot.renewal:no renewal failures
2017-09-29 10:31:54,469:INFO:certbot.hooks:Running post-hook command: sudo /opt/bitnami/ctlscript.sh start
Then I thought let's do it with verbose -v or -vv as rg305 suggested. When I startet this about 15 minutes later from a second shell it answered me:
Another instance of Certbot is already running.
So still the issue remains, that I never see my prompt anymore when running certbot.
UPDATE
Now I just discovered, if I restart my server from the second shell I do get a reaction from the first shell (which is still in progress with certbot). Before I restart the server from the second shell the first shell looks like this:
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/www.myhomepage.com/fullchain.pem
/etc/letsencrypt/live/www.myhomepage.com/fullchain.pem (success)
no renewal failures
With the cursor waiting below the last line.
But after I restarted the server from the second shell, the first shell looks like this:
no renewal failures
Output from sudo:
2017-09-29T11:01:21.270890Z mysqld_safe Logging to '/opt/bitnami/mysql/data/mysqld.log'.
2017-09-29T11:01:21.287518Z mysqld_safe Starting mysqld.bin daemon with databases from /opt/bitnami/mysql/data
2017-09-29T11:05:32.913037Z mysqld_safe mysqld from pid file /opt/bitnami/mysql/data/mysqld.pid ended
Syntax OK
The last two lines Error output from sudo: and Syntax OK are written in red color.
Any help still very welcome.
I guess I have to solve this problem prior to creating a cron job for this?
Many thanks!
These are bitnami related issues so i suggest you post on their forums
You have renewed the certificates certificates and the post-hook fired.
Anything else is really not something this forum is designed to support (we all volunteer and it’s not fair for people who have certificate related issues for us to support web servers etc). The issues you have and are getting feedback on are related with how you have configured bitnami and are not caused by certbot.
Andrei
Hi Andrei,
Thanks for the help.
I will do so.
