Installing certbot on old 32-bit machine
My domain is: https://elgin.link (You may prefer http)
sudo snap install --classic certbot
mxxxq@ASUSxxxxx:~$ sudo snap install --classic certbot
error: snap "certbot" is not available on stable but is available to install on the
** following channels:**
   edge       snap install --edge certbot
   Please be mindful pre-release channels may include features not completely
   tested or implemented. Get more information with 'snap info certbot'.
Server version: Apache/2.4.56 (Debian)
Server built: 2023-04-02T03:06:01
Server's Module Magic Number: 20120211:126
Server loaded: APR 1.7.0, APR-UTIL 1.6.1, PCRE 8.39 2016-06-14
Compiled using: APR 1.7.0, APR-UTIL 1.6.1, PCRE 8.39 2016-06-14
NOTE! Architecture: 32-bit
Server MPM: prefork
threaded: no
forked: yes (variable process count)
Debian GNU/Linux 11
ME!
YES!
NO!
-bash: certbot: command not found (well, of course!)
Have you tried this lately?:
sudo snap refresh
If so, then it may be tooooo old for certbot via snap.
if so, I'd suggest you try: acme.sh
If all else fails, you could put the whole thing behind a Raspberry Pi!
[at least they are 64 bits]
Some other options might be to try the pip installation instructions, or some other client. I might suggest lego, you should be able to just copy the binary for your architecture onto your server and just run it.
