Installed correctly, but still says Certificate error using Edge
My domain is: ivorselby.co.uk
I ran this command: Microsoft Edge url of : https://www.ivorselby.co.uk/
It produced this output: This site is not secure
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): AWS EC2 Linux
It looks as if you have generated a certificate via the test server, not the production server
getting cert from server - ivorselby.co.uk
Certificate chain
 0 s:/CN=ivorselby.co.uk
   i:/CN=Fake LE Intermediate X1
 1 s:/CN=Fake LE Intermediate X1
   i:/CN=Fake LE Root X1
Certificate:
Issuer: CN=Fake LE Intermediate X1
Not Before: Jan  3 10:17:47 2018 GMT
Not After : Apr  3 10:17:47 2018 GMT
Subject: CN=ivorselby.co.uk
Public Key Algorithm: rsaEncryption
DNS:ivorselby.co.uk
How did you generate the certificate ?
I had used
sudo /home/ec2-user/certbot-auto --apache --expand -d ivorselby.co.uk -d www.ivorselby.co.uk –debug
But that said it had installed but gave certificate error in Edge, so I tried
sudo /home/ec2-user/certbot-auto --apache –staging
and still got the same response
“–staging” is the staging or test server which is the certificate you have installed - so try without the “–staging” flag
Tried it, but please see attached
I’m getting a similar error and got a big green A at https://www.ssllabs.com/ssltest/analyze.html?d=train.climate.com.au
But when I looked at the detail of Certificate #2: RSA 2048 bits (SHA256withRSA) - which I didn’t realize was there I see the problem is given …
Subject ssds.climate.com.au
Fingerprint SHA256: d2b12ed11e597649c9c8a2b92cb02603f70c1db858b8abb591087bda9710c6bf
Pin SHA256: cyouIXjepMNQXey2HARzBqf44EwI2glIFPapORIDm4Q=
Common names ssds.climate.com.au
Alternative names ssds.climate.com.au MISMATCH
Serial Number 03b5e5384e8e90fa633e8dcc68eebaaa2f73
Valid from Sun, 17 Dec 2017 12:01:32 UTC
Valid until Sat, 17 Mar 2018 12:01:32 UTC (expires in 1 month and 21 days)
Key RSA 2048 bits (e 65537)
Weak key (Debian) No
Issuer Let’s Encrypt Authority X3
AIA: http://cert.int-x3.letsencrypt.org/
Signature algorithm SHA256withRSA
Extended Validation No
Certificate Transparency No
OCSP Must Staple No
Revocation information OCSP
OCSP: http://ocsp.int-x3.letsencrypt.org
Revocation status Good (not revoked)
Trusted No NOT TRUSTED
Mozilla Apple Android Java Windows
And so I would like to remove all certs and start again. There must be some reference to ssds.climate.com.au in the train.climate.com.au certificate.
I have seen another thread indicating certbot delete ought to work but I’m on Ubuntu 16.04 LTS and the latest certbot is 0.19.0 so I don’t think that’s an option for me.
I’m not confident mucking around here and would appreciate any pointers.
Many thanks
Mike
