Running Debian 8.2, I am trying to follow the instructions to install using letsencrypt-auto, but it hangsfor a while at “Updating letsencrypt and virtual environment dependencies…”. I get the following error message:
Command "/home/mvd/.local/share/letsencrypt/bin/python2.7 -c "import setuptools, tokenize;__file__='/tmp/user/1000/pip-build-p0CMhA/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/user/1000/pip-pz5S01-record/install-record.txt --single-version-externally-managed --compile --install-headers /home/mvd/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/user/1000/pip-build-p0CMhA/cryptography
Clearly the problem is somehow related to the cryptography module, but I can’t get it to give me more useful output. Furthermore, trying to use the --help option does nothing but try to run the virtualenv update step again, so I can’t even see if there is a way to print more verbose output.
Update 1: If I manually activate the letsencrypt virtualenv and pip install cryptography, it appears to work. So why does it fail if I don’t do this?
Update 2: I have tried to run the developer instructions for installing a local copy. At the ./bootstrap/dev/venv.sh step, I get another error, but this time with more verbosity:
running build_ext
generating cffi module 'build/temp.linux-x86_64-2.7/_padding.c'
creating build/temp.linux-x86_64-2.7
generating cffi module 'build/temp.linux-x86_64-2.7/_constant_time.c'
generating cffi module 'build/temp.linux-x86_64-2.7/_openssl.c'
building '_openssl' extension
creating build/temp.linux-x86_64-2.7/build
creating build/temp.linux-x86_64-2.7/build/temp.linux-x86_64-2.7
x86_64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c build/temp.linux-x86_64-2.7/_openssl.c -o build/temp.linux-x86_64-2.7/build/temp.linux-x86_64-2.7/_openssl.o
x86_64-linux-gnu-gcc: internal compiler error: Killed (program cc1)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.9/README.Bugs> for instructions.
error: command 'x86_64-linux-gnu-gcc' failed with exit status 4
