Installation to site with Apache built from source
When I ran the certbot command: ./certbot-auto certonly --email webmaster@xxx.com -w /var/www/html -d server.xxx.com …etc
Failed to find executable apache2ctl in PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
and then I get:
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
http-01 challenge for server.xxx.com
http-01 challenge for server2.xxx.com
http-01 challenge fo rserver3.xxx.com
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
    /etc/letsencrypt/live/server.xxx.com/fullchain.pem
    /etc/letsencrypt/live/server.xxx.com/privkey.pem
    Your cert will expire on 2018-09-02. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again. To non-interactively renew all of your certificates, run
    “certbot-auto renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
root@seal:/usr/local/sw/Certbot# ./certbot-auto renew
Processing /etc/letsencrypt/renewal/server.xxx.com.conf
Cert not yet due for renewal
Could not choose appropriate plugin: The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(‘Cannot find Apache control command apache2ctl’,)
Attempting to renew cert (server.xxx.com) from /etc/letsencrypt/renewal/server.xxx.com.conf produced an unexpected error: The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(‘Cannot find Apache control command apache2ctl’,). Skipping.
/etc/letsencrypt/live/server.xxx.com/fullchain.pem (failure)
/etc/letsencrypt/live/server.xxx.com/fullchain.pem expires on 2018-09-02 (skipped)
My web server is (include version) is built from source (Apache 2.4.29)
The operating system my web server runs on is (include version):Ubuntu 16.04.4 LTS
I can login to a root shell on my machine.
I suspect that the problem is that the certbot is looking for the built-in apache2 installation rather than the actual running apache HTTP that is compiled and installed from source under /usr/local/apache
How can I get it to work to renew?
No, your problem is that certbot did exactly what you told it to do--obtain certs. Installing and configuring those is up to you. That's what the certonly parameter told it to do.
You would need to specify path to apachectl.
@danb35 I think the issue is when he run certbot renew…
It seems that the previous certs was using Apache plugin to renew, but he compiled that from source, which can’t find the new path (by default)
Then it returned the error message, Apache plugin is not working.
@georged
I believe there is a derivative to specify Apache install location… However I forget where it is…
You might want to add -i Apache after all parameters you entered. (E.g. certbot-auto certonly all parameters -i apache)
Thank you
@stevenzhu, thank you but if I install the apache plugin (sudo dnf install certbot-apache) wouln't expect the apache2ctl target rather than mine (/usr/local/apache/bin/apachectl)?
I also tried the -i apache option and get the same error:
Failed to find executable apache2ctl ....
See also
The Certbot Apache plugin has some per-OS builtin defaults related to Apache. For example, these are the ones on a Debian system:
    OS_DEFAULTS = dict(
        server_root="/etc/apache2",
        vhost_root="/etc/apache2/sites-available",
        vhost_files="*",
        logs_root="/var/log/apache2",
        version_cmd=['apache2ctl', '-v'],
        apache_cmd="apache2ctl",
        restart_cmd=['apache2ctl', 'graceful'],
        conftest_cmd=['apache2ctl', 'configtest'],
        enmod="a2enmod",
        dismod="a2dismod",
        le_vhost_ext="-le-ssl.conf",
        handle_mods=True,
        handle_sites=True,
        challenge_location="/etc/apache2",
        MOD_SSL_CONF_SRC=pkg_resources.resource_filename(
            "certbot_apache", "options-ssl-apache.conf")
You should be able to override each option with a command line option starting with --apache- and the name of the option (except with _ replaced by -). For example --apache-restart-cmd to set the restart_cmd option.
@danb35, the certs seem to be successfully installed according to the output listed above.
Congratulations! Your certificate and chain have been saved at:...
The renew is what fails.
I was using "installed," admittedly imprecisely, to refer to configuring Apache to use the new certs--the certonly command doesn't do that. But I'd overlooked the issue with renewal.
No cigar, unfortunately:
./certbot-auto renew --apache-server-root="/usr/local/apache" --apache-cmd=“apachectl”
usage:
certbot-auto [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] …
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: --apache-cmd apachectl
@danb35, no problem, I guess the question is what would install the certs properly to an apache installation built from source? Because the default instructions and installers seem to assume apache2 packaged installed.
It might be counterintuitive, but I believe the name of the option should be --apache-apache-cmd.
Unfortunately I get an error:
./certbot-auto renew --apache-server-root="/usr/local/apache" --apache-apache-cmd=“apachectl”
usage:
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default, it will attempt to use a webserver both for obtaining and installing the certificate.
certbot: error: unrecognized arguments: --apache-apache-cmd apachectl
At this point I am desperate, not being able to do the renewals. I am willing to wipe it all off and start from scratch. Is there any doc on how to install the certs from scratch and use my compiled version of apache (not the assumed apache2 package)?
@joohoi @bmw, do you know why neither form of this option is working to specify the apache_cmd configuration variable?
Could you just create a symlink from apache2ctl to apachectl?
I tried it, added the softlink and I also went through the docs and tried from scratch. This is what I get:
./certbot-auto certonly --webroot --email webmaster@mymail.com -w /var/www/html -d server1.com -d server2.com -d server3.com
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/server1.com.conf)
What would you like to do?
1: Keep the existing certificate for now
http-01 challenge for server1.com
http-01 challenge for server2.com
http-01 challenge for server3.com
    /etc/letsencrypt/live/server1.com/fullchain.pem
    /etc/letsencrypt/live/server1.com/privkey.pem
    Your cert will expire on 2018-09-03. To obtain a new or tweaked
root@server1:/usr/local/sw/Certbot# ./certbot-auto renew
Processing /etc/letsencrypt/renewal/server1.com.conf
Processing /etc/letsencrypt/renewal/server3.com.conf
The error was: NoInstallationError(‘Could not find configuration root’,)
Attempting to renew cert (server3.com) from /etc/letsencrypt/renewal/server3.com.conf produced an unexpected error: The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(‘Could not find configuration root’,). Skipping.
/etc/letsencrypt/live/server3.com/fullchain.pem (failure)
/etc/letsencrypt/live/server1.com/fullchain.pem expires on 2018-09-03 (skipped)
--apache-server-root is using ASCII quotation marks, but --apache-apache-cmd is using Unicode left and right quotation marks. Did the forum software edit the post to use fancy quotes? Which quotes did the command actually run use?
What's in /etc/letsencrypt/renewal/server3.com.conf? It's probably using the Apache options you used when originally creating the certificate, not the new ones you used when creating the server1.com certificate today.
(Do you still need both certificates? The server1.com certificate includes the name server3.com. If you don't need it, you could update your Apache configuration to stop using the server3.com certificate and then delete it with certbot delete.)
I was able to get a clean renewal by removing the cert that was giving problems. I did it a manual way and it worked:
rm -rf /etc/letsencrypt/live/${DOMAIN}
rm /etc/letsencrypt/renewal/${DOMAIN}.conf
Thank you all for your help but I would be (and I am sure others in the community) will be grateful if there is some docs on how to install the beautiful certbot with cases that apache is compiled by source.
