Hello!
I'm using the webroot plugin with apache2 and Debian 7 (latest).
I can't use the auto procedure because DNS problem: NXDOMAIN looking up A for xxx
-No problem- I prefer the webroot. BUT
With webroot I get the certificate but I can't install it into my apache files.
Here is the problem:
when I update my config file for secure SUBDOMAIN on SITE1
SITE2 (another virtualhost) is using that same certificate (from SITE1) and of course Chrome reports it.
What am I doing wrong? A Big thank you!
/etc/apache2/sites-enabled/mysubdomain.site1.ovh
SITE 1 (I would like an https subdomain for that site)
<VirtualHost *:443>
ServerAdmin myemail
ServerName mysubdomain.mydomain.com
ServerAlias mysubdomain.mydomain.com
DocumentRoot /home/mypath
<IfModule mod_headers.c> RequestHeader unset Proxy </IfModule>
<Directory /home/mypath> Options -Indexes FollowSymLinks MultiViews AllowOverride All </Directory>
LogLevel warn CustomLog /var/log/apache2/mypath-secure-access.log combined env=!local ServerSignature Off
SSLCertificateFile /etc/letsencrypt/live/secure.mysite.ovh/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/secure.mysite.ovh/privkey.pem Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost> </IfModule>
SITE2 (I don't want that site to use that certificate, I will use a new certificate later)
/etc/apache2/sites-enabled/site2.ovh
<VirtualHost *:80> ServerAdmin myemail ServerName mysite ServerAlias www.mysite DocumentRoot /home/mypath/www/ <Directory /home/mypath/www/> Options -Indexes FollowSymLinks MultiViews AllowOverride All <IfModule mod_expires.c> <FilesMatch "\.(jpe?g|png|gif)$"> ExpiresActive On ExpiresDefault "access plus 7 days" </FilesMatch> </IfModule> </Directory> LogLevel warn ScriptAlias /cgi-bin/ /home/mypath/cgi-bin/
CustomLog /var/log/apache2/mypath-access.log combined env=!local ServerSignature Off RewriteEngine on RewriteCond %{HTTP_HOST} !^www.*$ RewriteRule ^(.*) http://www.%{HTTP_HOST}$1 [L,R=301] RewriteCond %{HTTP:range} !(^bytes=[^,]+(,[^,]+){0,9}$|^$) RewriteRule .* - [F] </VirtualHost>
Result: SITE2 is using the certificate from site1 when I try https://www.site2
THANK YOU
