ImportError: No module named enum
I ran this command: certbot
File "/usr/local/bin/certbot", line 7, in
  • from certbot.main import main*
  • File "/usr/local/lib/python2.7/dist-packages/certbot/main.py", line 10, in *
  • import josepy as jose*
  • File "/usr/local/lib/python2.7/dist-packages/josepy/init.py", line 44, in *
  • from josepy.interfaces import JSONDeSerializable*
  • File "/usr/local/lib/python2.7/dist-packages/josepy/interfaces.py", line 8, in *
  • from josepy import errors, util*
  • File "/usr/local/lib/python2.7/dist-packages/josepy/util.py", line 4, in *
  • import OpenSSL*
  • File "/usr/local/lib/python2.7/dist-packages/OpenSSL/init.py", line 8, in *
  • from OpenSSL import crypto, SSL*
  • File "/usr/local/lib/python2.7/dist-packages/OpenSSL/crypto.py", line 12, in *
  • from cryptography import x509*
  • File "/usr/local/lib/python2.7/dist-packages/cryptography/x509/init.py", line 7, in *
  • from cryptography.x509 import certificate_transparency*
  • File "/usr/local/lib/python2.7/dist-packages/cryptography/x509/certificate_transparency.py", line 8, in *
  • from enum import Enum*
The operating system my web server runs on is (include version): Ubuntu 20.04
Hi @ryoung,
This can happen if you try to install Certbot to your system using pip. There is a warning against doing so in the documentation. It can easily break due to the way Linux systems manage Python packages.
The best way to install Certbot is to use the instructions from https://certbot.eff.org/instructions. You may want to remove the /usr/local/bin/certbot file so that it does not interfere with the working installation.
Unfortunately I didn't install with pip, but with apt.
However, once I uninstalled everything I was able to run the certbot command from the user/bin.
Thanks!
Cool!
/usr/bin/certbot comes from apt, but /usr/local/bin/certbot definitely comes from pip.
I think the /usr/local/bin/ has priority in your path on Ubuntu; it may have been taking priority over the one from apt.
Glad to hear you got it working.
