IIS issue adding certificates with letsencrypt-win-simple
I installed and ran letsencrypt on my iis machine and did so with lets encrypt simple. The first test certificate installed without issue. Ran the program. Answered a few questions. Selected the host to install certificate for and it did the rest.
Per these instructions.
Success.
I went to use it a second time and no longer get option to select the host. It asks me to Choose from one of the following options. I enter a host number and the process is completely different the second time around. It is aking for username and password for azure which I did not have to use the first time. The second site uses the same registrar as the first.
Not sure what I did wrong.
Your assistance is greatly appreciated.
hi @digper
The easiest way may be to post an issue on the authors github
I am not sure how you are getting the messages you are getting and the descriptions you have provided are too high level to troubleshoot (screenshots for example would have been useful)
Andrei
