Let's try this then:
./acme.sh --issue -d kytkin.pekant.fi --alpn --server https://acme-staging-v02.api.letsencrypt.org/directory
Same error
root@kytkin ~/.acme.sh # ./acme.sh --issue -d kytkin.pekant.fi --alpn --server https://acme-staging-v02.api.letsencrypt.org/directory
[Fri Aug 13 12:06:44 EEST 2021] Using CA: https://acme-staging-v02.api.letsencrypt.org/directory
[Fri Aug 13 12:06:44 EEST 2021] Standalone alpn mode.
[Fri Aug 13 12:06:44 EEST 2021] Registering account: https://acme-staging-v02.api.letsencrypt.org/directory
[Fri Aug 13 12:06:46 EEST 2021] Registered
[Fri Aug 13 12:06:46 EEST 2021] ACCOUNT_THUMBPRINT='6vCynACaz9V5PVJL67j1-WjYVB9q7EaA2IZu_OufCfY'
[Fri Aug 13 12:06:46 EEST 2021] Single domain='kytkin.pekant.fi'
[Fri Aug 13 12:06:46 EEST 2021] Getting domain auth token for each domain
[Fri Aug 13 12:06:47 EEST 2021] Getting webroot for domain='kytkin.pekant.fi'
[Fri Aug 13 12:06:48 EEST 2021] Verifying: kytkin.pekant.fi
[Fri Aug 13 12:06:48 EEST 2021] Starting tls server.
[Fri Aug 13 12:06:50 EEST 2021] Pending, The CA is processing your order, please just wait. (1/30)
[Fri Aug 13 12:06:53 EEST 2021] kytkin.pekant.fi:Verify error:Connection refused
Odd. This almost looks like there's a firewall blocking port 443 inbound traffic. I noticed apache returned a 500 error earlier on port 443 when it was enabled.
Well there is now webisite anymore... It worked fine when there was a website. So I think this is not firewall problem.
Do I need to add some txt value to DNS?
Not for ALPN-01. The TXT records are for DNS-01.
Old certbot was using webroot on this same server.
If you were using webroot http-01, why not use that with acme.sh rather than alpn-01?
Wee I have tried but I do not know how
./acme.sh --issue -d kytkin.pekant.fi --server https://acme-staging-v02.api.letsencrypt.org/directory -w /var/www/html
What's the result? I'm assuming the webroot directory you specified is correct.
[Fri Aug 13 12:38:37 EEST 2021] Using CA: https://acme-staging-v02.api.letsencrypt.org/directory
[Fri Aug 13 12:38:38 EEST 2021] Single domain='kytkin.pekant.fi'
[Fri Aug 13 12:38:38 EEST 2021] Getting domain auth token for each domain
[Fri Aug 13 12:38:41 EEST 2021] Getting webroot for domain='kytkin.pekant.fi'
[Fri Aug 13 12:38:41 EEST 2021] Verifying: kytkin.pekant.fi
[Fri Aug 13 12:38:41 EEST 2021] Pending, The CA is processing your order, please just wait. (1/30)
[Fri Aug 13 12:38:44 EEST 2021] kytkin.pekant.fi:Verify error:Fetching http://kytkin.pekant.fi/.well-known/acme-challenge/9MbNnZf7DdQRvEqSPBwVWLW9wlDnWj-o_hSv3m9rWt0: Connection refused
Does it try to use port 80`?
It does, but it's not standalone. Apache is serving the files.
I started apatche and now it worked!
Now try this:
./acme.sh --issue -d kytkin.pekant.fi --server https://acme-v02.api.letsencrypt.org/directory -w /var/www/html
I'm seeing good things...
Yes It is worked Now I believe! Thank you very much!
