My domain is: myinchdeal.com
How do I get my website verified so people know that their information is safe?
HELP
HELP
Hi @Brannon
start with some basics:
If you have root access, select a client.
If not, your options are limited. May be it’s impossible to use Letsencrypt.
Do you think you can link where to start.
I read all of it but i dont know where to go yo do it.
Yep, checking the domain - Grade E - myinchdeal.com - Make your website better - DNS, redirects, mixed content, certificates
All relevant things are green.
PS: So both connections - non-www and www - have a correct certificate, no mixed content, no dropped or blocked connection, no http.
