My domain is: felinesoulsystems.com
I ran this command: certbot revoke --nginx --cert-path /etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem -d www.felinesoulsystems.com -d felinesoulsystems.com which produced: “Congratulations! You have successfully revoked the certificate that was located
at /etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem”
Then i ran certbot delete --nginx --cert-path /etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem -d www.felinesoulsystems.com -d felinesoulsystems.com which produced a log, and asked me to enter the number corresponding to the domain i was deleting. I did so (pressed 8), and it responded with “Deleted all files relating to certificate” admin.felinesoulsystems.com.
It produced this output: (see above)
My web server is (include version): nginx/1.10.3
The operating system my web server runs on: Linux 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u1 (2017-06-18) x86_64 GNU/Linux
My hosting provider, if applicable, is: my own Google Cloud
It all started this morning. I have a site under admin.felinesoulsystems.com and a site under www.felinesoulsystrems.com. When i went to https://www.felinesoulsystems.com chrome would warn me that it was not secure. When i told it to ignore that, it would push me over to admin.felinesoulsystems.com. Looking closer with “certbot certificates” i saw that i had a certificate for admin.felinesoulsystems.com and felinesoulsystems.com but not www.felinesoulsystems.com. www should be the default subdomain anyway. I revoked the ceriificate and then deleted it (as seen above) in the hopes of creating a certificate with -d admin.felinesoulsystems.com and then one with -d www.felinesoulsystems.com -d felinesoulsystems.com as that’s how they are in the two ngnix configuration files that i have setup.
Now when i run “sudo certbot --cert-name felinesoulsystems.com --nginx -d www.felinesoulsystems.com -d admin.felinesoulsystems.com -d felinesoulsystems.com” i see:
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen(’/etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem’,‘r’) error:2006D080:BIO routines:BIO_new_file:no such file)
nginx: configuration file /etc/nginx/nginx.conf test failed
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError(‘Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] BIO_new_file("/etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen(’/etc/letsencrypt/live/admin.felinesoulsystems.com/fullchain.pem’,‘r’) error:2006D080:BIO routines:BIO_new_file:no such file)\nnginx: configuration file /etc/nginx/nginx.conf test failed\n’,)
What do i do to fix this on a live server?
In the future when i have a need for subdomain.felinesoulsystems.com i’ll just create new certificate for that, right? Am i Doing It Wrong? Should i only have one cert for felinesoulsytems.com and then use the same config lines for each nginx site config file?
