I keep receiving emails that my certificate will expire
Hi all. I keep getting emails that my domain will expire from letsencrypt. But, when I go to renew, certbot tells me that I don’t need to renew. Any insights into what’s going on?
Thanks!
My domain is: www.largearcade.com
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.largearcade.com.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
http-01 challenge for largearcade.com
http-01 challenge for www.largearcade.com
Generating key (2048 bits): /etc/letsencrypt/keys/0003_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0003_csr-certbot.pem
**          (The test certificates below have not been saved.)
  /etc/letsencrypt/live/www.largearcade.com/fullchain.pem (success)
**          (The test certificates above have not been saved.)
The operating system my web server runs on is (include version): debian
My hosting provider, if applicable, is: digital ocean
Hi @spinlock99,
Please read the bottom of the renewal reminder e-mail, which tries to explain this situation. If you can think of a way we could have made it clearer, I'd be glad to hear suggestions.
For details about when we send these emails, please visit Expiration Emails - Let's Encrypt. In particular, note that this reminder email is still sent if you've obtained a slightly different certificate by adding or removing names. If you've replaced this certificate with a newer one that covers more or fewer names than the list above, you may be able to ignore this message.
This certificate
has been superseded by this one
and therefore the old certificate doesn't need to be renewed. However, there's no way for the CA to know this because it doesn't know whether these certificates are used on the same server or different servers. Therefore, the renewal reminder is for the old certificate, which has not been replaced by an identical certificate (but doesn't need to be).
gotcha. that makes sense.
it might have been more clear if the email included all domains and certificates tied to me rather than just the one? honestly, i just recently set up the certificate so i’m still learning.
thanks!
