I have web site with TMG as a proxy
My domain is: data.hptn.org
I ran this command: wacs.exe as administrator
It produced this output: Target generated using plugin IIS: data.hptn.org
Authorize identifier: data.hptn.org
Authorizing data.hptn.org using http-01 validation (SelfHosting)
“type”: “urn:ietf:params:acme:error:unauthorized”,
“detail”: "Invalid response from https://data.hptn.org/.well-known/acme-challe
nge/Icq_P4hSnNKoe07yUOzfTOp6YcBRhV_Ze2PStWqWngg [74.122.46.125]: “\r\n<html xmlns=\“http””,
“status”: 403
Authorization result: invalid
My web server is (include version): IIS version8.5
The operating system my web server runs on is (include version): windows server 2012 R2
My hosting provider, if applicable, is: host internally with TMG up front
A simple Windows ACMEv2 client (WACS)
Software version 2.1.5.742 (RELEASE, PLUGGABLE)
ACME server https://acme-v02.api.letsencrypt.org/
IIS version 8.5
Running with administrator credentials
Scheduled task not configured yet
Please report issues at https://github.com/win-acme/win-acme
Welcome to the forum, @TatianaL! It looks like you are using win-acme, also known as WACS.
@WouterTinus, since you wrote win-acme, would you mind taking a look at @TatianaL’s problem? Thanks!
Hi @TatianaL, I’m not sure what you mean by TMG that is “in front” of your IIS, but for the default validation method (SelfHosting) to work, requests to port 80 must land on the same server that you are running win-acme on. If that is not the case you have to pick “advanced” mode from the main menu and choose another validation method when asked.
Thank you. The TMG is indeed Microsoft Forefront Threat Management Gateway. The web server is not open to the internet and web application runs though this proxy. What another another validation method ?
Hi @TatianaL
I wrote an article a while ago https://www.linkedin.com/pulse/lets-encrypt-part-1-issuing-installing-certificates-andrei-hawke/
This talks about how to set up the .well-known path of an IIS application
This part of your server should not return 403 codes as it’s used for public verification (other things apart from Let’s Encrypt)
If you are not comfortable doing this then have a look at the DNS challenge
I find that most admins may not have access to the DNS records so updating your IIS Web Server to let the .well-know path publicly available may be the best option
