I am impacted by the security problem of TLS-SNI
Hello,
I am impacted by the security problem of TLS-SNI.
My site runs on Ubuntu apache.
https://www.hightechplace.com/
If I understood correctly on Apache I can not use “–preferred-challenges http”?
./letsencrypt-auto --prefered-challenges http -d hightechplace.com
What is the solution on Apache?
Thanks for your help.
Mathieu
As written in Solution: Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA , you can use the manual webroot authenticator and use the --installer apache flag.
Thank you. It works :slight_smile:
If its a little help:
./letsencrypt-auto --installer apache --preferred-challenges http -d www.hightechplace.com
