HTTPS not working outside localhost!
Hello there!
Need some help with my server setup and configuration.
Been trying on my own for days now and would be happy to have this solved by the weekend.
Using xampp and apache on windows 7 and "had" HTTP running fine both public and local.
Installed wildcard certificate using certbot and after that I could not access HTTP or HTTPS outside localhost.
Both HTTP and HTTPS works fine on localhost but when I try to enter my website with a device on same network it does not work.
I have tried this out with other internet connections too and same thing can't be reached outside localhost.
Could this be an issue with the ports or firewall?
Port 80 and port 443 open on my local ip TCP protocol.
Microsoft Edge Browser:
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
www.mywebsite.net is using a protocol that is not supported.
Mozilla Firefox Browser:
Secure Connection Failed
An error occurred during a connection to mywebsite.net. Cannot communicate securely with peer: no common encryption algorithm
Error code: SSL_ERROR_NO_CYPHER_OVERLAP
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
Also to note my domain is hosted by one.com and it redirects to https://www.mywebsite.net is this bad or how its supposed to be?
Need this setup to be as secure as possible, its for a webshop with user accounts so all help and tips are welcome here or in my inbox!
Can gather more information and data just tell me whats needed.
Also, sorry if I explain bad or bad written it's getting late here!
My web server is (xampp apache)
The operating system my web server runs on is (Windows 7)
My hosting provider, if applicable, is: one.com
I can login to a root shell on my machine (yes)
I'm using a control panel to manage my site (XAMPP Control Panel v3.2.4)
The version of my client is (Certbot 1.10.1)
I will post my configurations down below.
D:\XAMPP\apache\conf\httpd.conf
# This is the main Apache HTTP server configuration file. It contains the
# configuration directives that give the server its instructions.
# See URL:http://httpd.apache.org/docs/2.4/ for detailed information.
# In particular, see
# URL:http://httpd.apache.org/docs/2.4/mod/directives.html
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do not begin
# with "/", the value of ServerRoot is prepended -- so "logs/access_log"
# with ServerRoot set to "/usr/local/apache2" will be interpreted by the
# server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
# will be interpreted as '/logs/access_log'.
# NOTE: Where filenames are specified, you must use forward slashes
# instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
# If a drive letter is omitted, the drive on which httpd.exe is located
# will be used by default. It is recommended that you always supply
# an explicit drive letter in absolute paths to avoid confusion.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path.  If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used.  If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
Define SRVROOT "D:/XAMPP/apache"
ServerRoot "D:/XAMPP/apache"
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:logs
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
LoadModule access_compat_module modules/mod_access_compat.so
LoadModule actions_module modules/mod_actions.so
LoadModule alias_module modules/mod_alias.so
LoadModule allowmethods_module modules/mod_allowmethods.so
LoadModule asis_module modules/mod_asis.so
LoadModule auth_basic_module modules/mod_auth_basic.so
#LoadModule auth_digest_module modules/mod_auth_digest.so
#LoadModule auth_form_module modules/mod_auth_form.so
#LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_core_module modules/mod_authn_core.so
#LoadModule authn_dbd_module modules/mod_authn_dbd.so
#LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_file_module modules/mod_authn_file.so
#LoadModule authn_socache_module modules/mod_authn_socache.so
#LoadModule authnz_fcgi_module modules/mod_authnz_fcgi.so
#LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
LoadModule authz_core_module modules/mod_authz_core.so
#LoadModule authz_dbd_module modules/mod_authz_dbd.so
#LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_host_module modules/mod_authz_host.so
#LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule autoindex_module modules/mod_autoindex.so
#LoadModule brotli_module modules/mod_brotli.so
#LoadModule buffer_module modules/mod_buffer.so
#LoadModule cache_module modules/mod_cache.so
#LoadModule cache_disk_module modules/mod_cache_disk.so
#LoadModule cache_socache_module modules/mod_cache_socache.so
#LoadModule cern_meta_module modules/mod_cern_meta.so
LoadModule cgi_module modules/mod_cgi.so
#LoadModule charset_lite_module modules/mod_charset_lite.so
#LoadModule data_module modules/mod_data.so
#LoadModule dav_module modules/mod_dav.so
#LoadModule dav_fs_module modules/mod_dav_fs.so
LoadModule dav_lock_module modules/mod_dav_lock.so
#LoadModule dbd_module modules/mod_dbd.so
#LoadModule deflate_module modules/mod_deflate.so
LoadModule dir_module modules/mod_dir.so
#LoadModule dumpio_module modules/mod_dumpio.so
LoadModule env_module modules/mod_env.so
#LoadModule expires_module modules/mod_expires.so
#LoadModule ext_filter_module modules/mod_ext_filter.so
#LoadModule file_cache_module modules/mod_file_cache.so
#LoadModule filter_module modules/mod_filter.so
#LoadModule http2_module modules/mod_http2.so
LoadModule headers_module modules/mod_headers.so
#LoadModule heartbeat_module modules/mod_heartbeat.so
#LoadModule heartmonitor_module modules/mod_heartmonitor.so
#LoadModule ident_module modules/mod_ident.so
#LoadModule imagemap_module modules/mod_imagemap.so
LoadModule include_module modules/mod_include.so
LoadModule info_module modules/mod_info.so
LoadModule isapi_module modules/mod_isapi.so
#LoadModule lbmethod_bybusyness_module modules/mod_lbmethod_bybusyness.so
#LoadModule lbmethod_byrequests_module modules/mod_lbmethod_byrequests.so
#LoadModule lbmethod_bytraffic_module modules/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_heartbeat_module modules/mod_lbmethod_heartbeat.so
#LoadModule ldap_module modules/mod_ldap.so
#LoadModule logio_module modules/mod_logio.so
LoadModule log_config_module modules/mod_log_config.so
#LoadModule log_debug_module modules/mod_log_debug.so
#LoadModule log_forensic_module modules/mod_log_forensic.so
#LoadModule lua_module modules/mod_lua.so
#LoadModule macro_module modules/mod_macro.so
#LoadModule md_module modules/mod_md.so
LoadModule mime_module modules/mod_mime.so
#LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
#LoadModule proxy_connect_module modules/mod_proxy_connect.so
#LoadModule proxy_express_module modules/mod_proxy_express.so
#LoadModule proxy_fcgi_module modules/mod_proxy_fcgi.so
#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
#LoadModule proxy_hcheck_module modules/mod_proxy_hcheck.so
#LoadModule proxy_html_module modules/mod_proxy_html.so
#LoadModule proxy_http_module modules/mod_proxy_http.so
#LoadModule proxy_http2_module modules/mod_proxy_http2.so
#LoadModule proxy_scgi_module modules/mod_proxy_scgi.so
#LoadModule proxy_uwsgi_module modules/mod_proxy_uwsgi.so
#LoadModule proxy_wstunnel_module modules/mod_proxy_wstunnel.so
#LoadModule ratelimit_module modules/mod_ratelimit.so
#LoadModule reflector_module modules/mod_reflector.so
#LoadModule remoteip_module modules/mod_remoteip.so
#LoadModule request_module modules/mod_request.so
#LoadModule reqtimeout_module modules/mod_reqtimeout.so
LoadModule rewrite_module modules/mod_rewrite.so
#LoadModule sed_module modules/mod_sed.so
#LoadModule session_module modules/mod_session.so
#LoadModule session_cookie_module modules/mod_session_cookie.so
#LoadModule session_crypto_module modules/mod_session_crypto.so
#LoadModule session_dbd_module modules/mod_session_dbd.so
LoadModule setenvif_module modules/mod_setenvif.so
#LoadModule slotmem_plain_module modules/mod_slotmem_plain.so
#LoadModule slotmem_shm_module modules/mod_slotmem_shm.so
#LoadModule socache_dbm_module modules/mod_socache_dbm.so
#LoadModule socache_memcache_module modules/mod_socache_memcache.so
#LoadModule socache_redis_module modules/mod_socache_redis.so
LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
#LoadModule speling_module modules/mod_speling.so
LoadModule ssl_module modules/mod_ssl.so
LoadModule status_module modules/mod_status.so
#LoadModule substitute_module modules/mod_substitute.so
#LoadModule unique_id_module modules/mod_unique_id.so
#LoadModule userdir_module modules/mod_userdir.so
#LoadModule usertrack_module modules/mod_usertrack.so
LoadModule version_module modules/mod_version.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
#LoadModule watchdog_module modules/mod_watchdog.so
#LoadModule xml2enc_module modules/mod_xml2enc.so
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User daemon
Group daemon
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. admin@your-domain.com
ServerAdmin postmaster@localhost
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
ServerName localhost:80
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
    AllowOverride none
    Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "D:/XAMPP/htdocs"
<Directory "D:/XAMPP/htdocs">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    Options Indexes FollowSymLinks Includes ExecCGI
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   AllowOverride FileInfo AuthConfig Limit
    AllowOverride All
    # Controls who can get stuff from this server.
    Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
    DirectoryIndex index.php index.pl index.cgi index.asp index.shtml index.html index.htm \
                   default.php default.pl default.cgi default.asp default.shtml default.html default.htm \
                   home.php home.pl home.cgi home.asp home.shtml home.html home.htm
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "logs/error.log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here.  Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    #CustomLog "logs/access.log" common
    # If you prefer a logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    CustomLog "logs/access.log" combined
</IfModule>
<IfModule alias_module>
    # Redirect: Allows you to tell clients about documents that used to
    # exist in your server's namespace, but do not anymore. The client
    # will make a new request for the document at its new location.
    # Example:
    # Redirect permanent /foo http://www.example.com/bar
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "D:/XAMPP/cgi-bin/"
</IfModule>
<IfModule cgid_module>
    # ScriptSock: On threaded servers, designate the path to the UNIX
    # socket used to communicate with the CGI daemon of mod_cgid.
    #Scriptsock cgisock
</IfModule>
# "D:/XAMPP/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "D:/XAMPP/cgi-bin">
    AllowOverride All
    Options None
    Require all granted
</Directory>
<IfModule headers_module>
    # Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
    # backend servers which have lingering "httpoxy" defects.
    # 'Proxy' request header is undefined by the IETF, not listed by IANA
    RequestHeader unset Proxy early
</IfModule>
<IfModule mime_module>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig conf/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    AddHandler cgi-script .cgi .pl .asp
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    AddType text/html .shtml
    AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
<IfModule mime_magic_module>
    MIMEMagicFile "conf/magic"
</IfModule>
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile off
# Supplemental configuration
# The configuration files in the conf/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
Include conf/extra/httpd-mpm.conf
# Multi-language error messages
#Include conf/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
Include conf/extra/httpd-autoindex.conf
# Language settings
Include conf/extra/httpd-languages.conf
# User home directories
Include conf/extra/httpd-userdir.conf
# Real-time info on requests and configuration
Include conf/extra/httpd-info.conf
# Virtual hosts
Include conf/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include conf/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Attention! WEB_DAV is a security risk without a new userspecific configuration for a secure authentifcation
#Include conf/extra/httpd-dav.conf
# Various default settings
#Include conf/extra/httpd-default.conf
# Implements a proxy/gateway for Apache.
Include "conf/extra/httpd-proxy.conf"
Include "conf/extra/httpd-default.conf"
# XAMPP settings
Include "conf/extra/httpd-xampp.conf"
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include conf/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
Include conf/extra/httpd-ssl.conf
# Note: The following must must be present to support
#       starting without SSL on platforms with no /dev/random equivalent
#       but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
# XAMPP: We disable operating system specific optimizations for a listening
# socket by the http protocol here. IE 64 bit make problems without this.
AcceptFilter http none
AcceptFilter https none
# AJP13 Proxy
<IfModule mod_proxy.c>
<IfModule mod_proxy_ajp.c>
Include "conf/extra/httpd-ajp.conf"
</IfModule>
</IfModule>
D:\XAMPP\apache\conf\extra\httpd-xampp.conf
# XAMPP settings
<IfModule mod_rewrite.c>
    RewriteEngine On
    # Redirect /xampp folder to https
    RewriteCond %{HTTPS} !=on
    RewriteCond %{REQUEST_URI} xampp
    RewriteRule ^(.*) https://%{SERVER_NAME}$1 [R,L]
    # Redirect /phpMyAdmin folder to https
    RewriteCond %{REQUEST_URI} phpmyadmin
    # Redirect /security folder to https
    RewriteCond %{REQUEST_URI} security
    # Redirect /webalizer folder to https
    RewriteCond %{REQUEST_URI} webalizer
</IfModule>
<IfModule env_module>
    SetEnv MIBDIRS "D:/XAMPP/php/extras/mibs"
    SetEnv MYSQL_HOME "\\xampp\\mysql\\bin"
    SetEnv OPENSSL_CONF "D:/XAMPP/apache/bin/openssl.cnf"
    SetEnv PHP_PEAR_SYSCONF_DIR "\\xampp\\php"
    SetEnv PHPRC "\\xampp\\php"
    SetEnv TMP "\\xampp\\tmp"
</IfModule>
# PHP-Module setup
LoadFile "D:/XAMPP/php/php7ts.dll"
LoadFile "D:/XAMPP/php/libpq.dll"
LoadModule php7_module "D:/XAMPP/php/php7apache2_4.dll"
LoadFile "D:/XAMPP/php/libsqlite3.dll"
<FilesMatch "\.php$">
    SetHandler application/x-httpd-php
</FilesMatch>
<FilesMatch "\.phps$">
    SetHandler application/x-httpd-php-source
</FilesMatch>
# PHP-CGI setup
#<FilesMatch "\.php$">
#    SetHandler application/x-httpd-php-cgi
#</FilesMatch>
#<IfModule actions_module>
#    Action application/x-httpd-php-cgi "/php-cgi/php-cgi.exe"
#</IfModule>
<IfModule php7_module>
    PHPINIDir "D:/XAMPP/php"
</IfModule>
    AddType text/html .php .phps
</IfModule>
ScriptAlias /php-cgi/ "D:/XAMPP/php/"
<Directory "D:/XAMPP/php">
    AllowOverride None
    Options None
    Require all denied
    <Files "php-cgi.exe">
          Require all granted
    </Files>
</Directory>
        SetHandler cgi-script
    </FilesMatch>
        SetHandler None
    </FilesMatch>
</Directory>
<Directory "D:/XAMPP/htdocs/xampp">
    	<Files "status.php">
    		php_admin_flag safe_mode off
    	</Files>
    </IfModule>
    AllowOverride AuthConfig
</Directory>
    Alias /licenses "D:/XAMPP/licenses/"
    <Directory "D:/XAMPP/licenses">
        Options +Indexes
        <IfModule autoindex_color_module>
            DirectoryIndexTextColor  "#000000"
            DirectoryIndexBGColor "#f8e8a0"
            DirectoryIndexLinkColor "#bb3902"
            DirectoryIndexVLinkColor "#bb3902"
            DirectoryIndexALinkColor "#bb3902"
        </IfModule>
        Require local
        ErrorDocument 403 /error/XAMPP_FORBIDDEN.html.var
   </Directory>
    Alias /phpmyadmin "D:/XAMPP/phpMyAdmin/"
    <Directory "D:/XAMPP/phpMyAdmin">
        Require local
    </Directory>
    Alias /webalizer "D:/XAMPP/webalizer/"
    <Directory "D:/XAMPP/webalizer">
    		<Files "webalizer.php">
    		</Files>
        </IfModule>
        Require local
    </Directory>
</IfModule>
D:\XAMPP\apache\conf\extra\httpd-vhosts.conf
# Virtual Hosts
# Required modules: mod_log_config
# If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs/2.4/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# Use name-based virtual hosting.
##NameVirtualHost *:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for all requests that do not
# match a ##ServerName or ##ServerAlias in any <VirtualHost> block.
##<VirtualHost *:80>
    ##ServerAdmin webmaster@dummy-host.example.com
    ##DocumentRoot "D:/XAMPP/htdocs/dummy-host.example.com"
    ##ServerName dummy-host.example.com
    ##ServerAlias www.dummy-host.example.com
    ##ErrorLog "logs/dummy-host.example.com-error.log"
    ##CustomLog "logs/dummy-host.example.com-access.log" common
##</VirtualHost>
    ##ServerAdmin webmaster@dummy-host2.example.com
    ##DocumentRoot "D:/XAMPP/htdocs/dummy-host2.example.com"
    ##ServerName dummy-host2.example.com
    ##ErrorLog "logs/dummy-host2.example.com-error.log"
    ##CustomLog "logs/dummy-host2.example.com-access.log" common
##</VirtualHost>
# http
<VirtualHost *:80>
    DocumentRoot "D:/xampp/htdocs"
    ServerName mywebsite.net
    <Directory "D:/xampp/htdocs">
        Options All
        AllowOverride All
        Require all granted
        RewriteEngine On
        RewriteRule ^(.*)$ https://%{HTTP_HOST}$1 [R=301,L]
    </Directory>
</VirtualHost>
# https
<VirtualHost *:443>
    ServerAlias www.mywebsite.net
        AllowOverride All
        Require all granted
    </Directory>
    ErrorLog "D:/xampp/apache/logs/error.log"
    CustomLog "D:/xampp/apache/logs/access.log" common
    SSLEngine on
    SSLCertificateFile "D:/xampp/apache/conf/ssl.crt/cert.pem"
    SSLCertificateKeyFile "D:/xampp/apache/conf/ssl.key/privkey.pem"
    Header always set Strict-Transport-Security "max-age=63072000"
</VirtualHost>
D:\XAMPP\apache\conf\extra\httpd-ssl.conf
# This is the Apache server configuration file providing SSL support.
# It contains the configuration directives to instruct the server how to
# serve pages over an https connection. For detailed information about these
# directives see <URL:http://httpd.apache.org/docs/2.4/mod/mod_ssl.html>
# Required modules: mod_log_config, mod_setenvif, mod_ssl,
#          socache_shmcb_module (for default value of SSLSessionCache)
# Pseudo Random Number Generator (PRNG):
# Configure one or more sources to seed the PRNG of the SSL library.
# The seed data should be of good random quality.
# WARNING! On some platforms /dev/random blocks if not enough entropy
# is available. This means you then cannot use the /dev/random device
# because it would lead to very long connection times (as long as
# it requires to make more entropy available). But usually those
# platforms additionally provide a /dev/urandom device which doesn't
# block. So, if available, use this one instead. Read the mod_ssl User
# Manual for more details.
#SSLRandomSeed startup file:/dev/random  512
#SSLRandomSeed startup file:/dev/urandom 512
#SSLRandomSeed connect file:/dev/random  512
#SSLRandomSeed connect file:/dev/urandom 512
# When we also provide SSL we have to listen to the
# standard HTTP port (see above) and to the HTTPS port
Listen 443
##  SSL Global Context
##  All SSL configuration in this context applies both to
##  the main server and all SSL-enabled virtual hosts.
#   SSL Cipher Suite:
#   List the ciphers that the client is permitted to negotiate,
#   and that httpd will negotiate as the client of a proxied server.
#   See the OpenSSL documentation for a complete list of ciphers, and
#   ensure these follow appropriate best practices for this deployment.
#   httpd 2.2.30, 2.4.13 and later force-disable aNULL, eNULL and EXP ciphers,
#   while OpenSSL disabled these by default in 0.9.8zf/1.0.0r/1.0.1m/1.0.2a.
SSLCipherSuite HIGH:MEDIUM:!MD5:!RC4:!3DES
SSLProxyCipherSuite HIGH:MEDIUM:!MD5:!RC4:!3DES
#  By the end of 2016, only TLSv1.2 ciphers should remain in use.
#  Older ciphers should be disallowed as soon as possible, while the
#  kRSA ciphers do not offer forward secrecy.  These changes inhibit
#  older clients (such as IE6 SP2 or IE8 on Windows XP, or other legacy
#  non-browser tooling) from successfully connecting.
#  To restrict mod_ssl to use only TLSv1.2 ciphers, and disable
#  those protocols which do not support forward secrecy, replace
#  the SSLCipherSuite and SSLProxyCipherSuite directives above with
#  the following two directives, as soon as practical.
# SSLCipherSuite HIGH:MEDIUM:!SSLv3:!kRSA
# SSLProxyCipherSuite HIGH:MEDIUM:!SSLv3:!kRSA
#   User agents such as web browsers are not configured for the user's
#   own preference of either security or performance, therefore this
#   must be the prerogative of the web server administrator who manages
#   cpu load versus confidentiality, so enforce the server's cipher order.
SSLHonorCipherOrder on
#   SSL Protocol support:
#   List the protocol versions which clients are allowed to connect with.
#   Disable SSLv3 by default (cf. RFC 7525 3.1.1).  TLSv1 (1.0) should be
#   disabled as quickly as practical.  By the end of 2016, only the TLSv1.2
#   protocol or later should remain in use.
SSLProtocol all -SSLv3 -TLSv1 -TLSv1.1
SSLProxyProtocol all -SSLv3 -TLSv1 -TLSv1.1
#   Pass Phrase Dialog:
#   Configure the pass phrase gathering process.
#   The filtering dialog program (`builtin' is an internal
#   terminal dialog) has to provide the pass phrase on stdout.
SSLPassPhraseDialog  builtin
#   Inter-Process Session Cache:
#   Configure the SSL Session Cache: First the mechanism
#   to use and second the expiring timeout (in seconds).
#SSLSessionCache "shmcb:D:/XAMPP/apache/logs/ssl_scache(512000)"
SSLSessionCacheTimeout  300
#   OCSP Stapling (requires OpenSSL 0.9.8h or later)
#   This feature is disabled by default and requires at least
#   the two directives SSLUseStapling and SSLStaplingCache.
#   Refer to the documentation on OCSP Stapling in the SSL/TLS
#   How-To for more information.
#   Enable stapling for all SSL-enabled servers:
#SSLUseStapling On
#   Define a relatively small cache for OCSP Stapling using
#   the same mechanism that is used for the SSL session cache
#   above.  If stapling is used with more than a few certificates,
#   the size may need to be increased.  (AH01929 will be logged.)
#SSLStaplingCache "shmcb:${SRVROOT}/logs/ssl_stapling(32768)"
#   Seconds before valid OCSP responses are expired from the cache
#SSLStaplingStandardCacheTimeout 3600
#   Seconds before invalid OCSP responses are expired from the cache
#SSLStaplingErrorCacheTimeout 600
## SSL Virtual Host Context
<VirtualHost _default_:443>
#   General setup for the virtual host
DocumentRoot "D:/XAMPP/htdocs/"
ServerName mywebsite.net:443
ServerAdmin email@hotmail.com
ErrorLog "D:/XAMPP/apache/logs/error.log"
TransferLog "D:/XAMPP/apache/logs/access.log"
#   SSL Engine Switch:
#   Enable/Disable SSL for this virtual host.
SSLEngine on
#   Server Certificate:
#   Point SSLCertificateFile "conf/ssl.crt/server.crt"
#   the certificate is encrypted, then you will be prompted for a
#   pass phrase.  Note that a kill -HUP will prompt again.  Keep
#   in mind that if you have both an RSA and a DSA certificate you
#   can configure both in parallel (to also allow the use of DSA
#   ciphers, etc.)
#   Some ECC cipher suites (http://www.ietf.org/rfc/rfc4492.txt)
#   require an ECC certificate which can also be configured in
#   parallel.
SSLCertificateFile "conf/ssl.crt/cert.pem"
#SSLCertificateFile "conf/ssl.crt/server.crt"
#   Server Private Key:
#   If the key is not combined with the certificate, use this
#   directive to point at the key file.  Keep in mind that if
#   you've both a RSA and a DSA private key you can configure
#   both in parallel (to also allow the use of DSA ciphers, etc.)
#   ECC keys, when in use, can also be configured in parallel
SSLCertificateKeyFile "conf/ssl.key/privkey.pem"
#SSLCertificateKeyFile "conf/ssl.key/server.key"
#   Server Certificate Chain:
#   Point SSLCertificateChainFile at a file containing the
#   concatenation of PEM encoded CA certificates which form the
#   certificate chain for the server certificate. Alternatively
#   the referenced file can be the same as SSLCertificateFile "conf/ssl.crt/server.crt"
#   certificate for convenience.
#SSLCertificateChainFile "${SRVROOT}/conf/server-ca.crt"
#   Certificate Authority (CA):
#   Set the CA certificate verification path where to find CA
#   certificates for client authentication or alternatively one
#   huge file containing all of them (file must be PEM encoded)
#   Note: Inside SSLCACertificatePath you need hash symlinks
#         to point to the certificate files. Use the provided
#         Makefile to update the hash symlinks after changes.
#SSLCACertificatePath "${SRVROOT}/conf/ssl.crt"
#SSLCACertificateFile "${SRVROOT}/conf/ssl.crt/ca-bundle.crt"
#   Certificate Revocation Lists (CRL):
#   Set the CA revocation path where to find CA CRLs for client
#   authentication or alternatively one huge file containing all
#   of them (file must be PEM encoded).
#   The CRL checking mode needs to be configured explicitly
#   through SSLCARevocationCheck (defaults to "none" otherwise).
#   Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath "${SRVROOT}/conf/ssl.crl"
#SSLCARevocationFile "${SRVROOT}/conf/ssl.crl/ca-bundle.crl"
#SSLCARevocationCheck chain
#   Client Authentication (Type):
#   Client certificate verification type and depth.  Types are
#   none, optional, require and optional_no_ca.  Depth is a
#   number which specifies how deeply to verify the certificate
#   issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth  10
#   TLS-SRP mutual authentication:
#   Enable TLS-SRP and set the path to the OpenSSL SRP verifier
#   file (containing login information for SRP user accounts).
#   Requires OpenSSL 1.0.1 or newer. See the mod_ssl FAQ for
#   detailed instructions on creating this file. Example:
#   "openssl srp -srpvfile ${SRVROOT}/conf/passwd.srpv -add username"
#SSLSRPVerifierFile "${SRVROOT}/conf/passwd.srpv"
#   Access Control:
#   With SSLRequire you can do per-directory access control based
#   on arbitrary complex boolean expressions containing server
#   variable checks and other lookup directives.  The syntax is a
#   mixture between C and Perl.  See the mod_ssl documentation
#   for more details.
#<Location />
#SSLRequire (    %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
#            and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \
#            and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \
#            and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
#            and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20       ) \
#           or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/
#</Location>
#   SSL Engine Options:
#   Set various options for the SSL engine.
#   o FakeBasicAuth:
#     Translate the client X.509 into a Basic Authorisation.  This means that
#     the standard Auth/DBMAuth methods can be used for access control.  The
#     user name is the `one line' version of the client's X.509 certificate.
#     Note that no password is obtained from the user. Every entry in the user
#     file needs this password: `xxj31ZMTZzkVA'.
#   o ExportCertData:
#     This exports two additional environment variables: SSL_CLIENT_CERT and
#     SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
#     server (always existing) and the client (only existing when client
#     authentication is used). This can be used to import the certificates
#     into CGI scripts.
#   o StdEnvVars:
#     This exports the standard SSL/TLS related `SSL_*' environment variables.
#     Per default this exportation is switched off for performance reasons,
#     because the extraction step is an expensive operation and is usually
#     useless for serving static content. So one usually enables the
#     exportation for CGI and SSI requests only.
#   o StrictRequire:
#     This denies access when "SSLRequireSSL" or "SSLRequire" applied even
#     under a "Satisfy any" situation, i.e. when it applies access is denied
#     and no other module can change it.
#   o OptRenegotiate:
#     This enables optimized SSL connection renegotiation handling when SSL
#     directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
    SSLOptions +StdEnvVars
</FilesMatch>
<Directory "D:/XAMPP/apache/cgi-bin">
</Directory>
#   SSL Protocol Adjustments:
#   The safe and default but still SSL/TLS standard compliant shutdown
#   approach is that mod_ssl sends the close notify alert but doesn't wait for
#   the close notify alert from client. When you need a different shutdown
#   approach you can use one of the following variables:
#   o ssl-unclean-shutdown:
#     This forces an unclean shutdown when the connection is closed, i.e. no
#     SSL close notify alert is sent or allowed to be received.  This violates
#     the SSL/TLS standard but is needed for some brain-dead browsers. Use
#     this when you receive I/O errors because of the standard approach where
#     mod_ssl sends the close notify alert.
#   o ssl-accurate-shutdown:
#     This forces an accurate shutdown when the connection is closed, i.e. a
#     SSL close notify alert is send and mod_ssl waits for the close notify
#     alert of the client. This is 100% SSL/TLS standard compliant, but in
#     practice often causes hanging connections with brain-dead browsers. Use
#     this only for browsers where you know that their SSL implementation
#     works correctly.
#   Notice: Most problems of broken clients are also related to the HTTP
#   keep-alive facility, so you usually additionally want to disable
#   keep-alive for those clients, too. Use variable "nokeepalive" for this.
#   Similarly, one has to force some clients to use HTTP/1.0 to workaround
#   their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
#   "force-response-1.0" for this.
BrowserMatch "MSIE [2-5]" \
         nokeepalive ssl-unclean-shutdown \
         downgrade-1.0 force-response-1.0
#   Per-Server Logging:
#   The home of a custom SSL log file. Use this when you want a
#   compact non-error SSL logfile on a virtual host basis.
CustomLog "D:/XAMPP/apache/logs/ssl_request.log" \
          "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
</VirtualHost>
D:\XAMPP\htdocs\api.htaccess
RewriteEngine On
RewriteCond   %{HTTP_HOST}   ^(mywebsite.net|www.mywebsite.net)$
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
C:\Windows\System32\drivers\etc\hosts
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
# localhost name resolution is handled within DNS itself.
#	127.0.0.1       localhost
#	::1             localhost
127.0.0.1 mywebsite.net www.mywebsite.net
apache error.log
[core:warn] [pid 7116:tid 152] AH00098: pid file D:/XAMPP/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[mpm_winnt:notice] [pid 7116:tid 152] AH00455: Apache/2.4.46 (Win64) OpenSSL/1.1.1g PHP/7.4.10 configured -- resuming normal operations
[mpm_winnt:notice] [pid 7116:tid 152] AH00456: Apache Lounge VC15 Server built: Aug  4 2020 11:50:23
[core:notice] [pid 7116:tid 152] AH00094: Command line: 'd:\\xampp\\apache\\bin\\httpd.exe -d D:/XAMPP/apache'
[mpm_winnt:notice] [pid 7116:tid 152] AH00418: Parent: Created child process 7776
[mpm_winnt:notice] [pid 7776:tid 328] AH00354: Child: Starting 150 worker threads.
Hello @rickest,
It is hard to debug the problem without the real domain. Anyway, the first thing you should do is modify conf file D:\XAMPP\apache\conf\extra\httpd-ssl.conf and replace this:
to this:
Restart apache and try again.
Cheers,
sahsanu
It seems that mywebsite.net is not a real domain name. Not telling us the domain name just makes it a lot harder for us to help you.
Also, welcome to the lets encrypt community!
I get that it makes it harder to do, its not live at the moment since its not working and im on a laptop atm.
Will change that, thank you! Any more debugging I should get on or a tool I could collect data with?
I ran "check-your-website.server-daten.de" tool earlier, will the data from that help out?
Thanks, I like it here already and the tutorial to get started was great!
When your site is reachable outside your network you can use SSL Server Test (Powered by Qualys SSL Labs) to check whether your certificate, cipher suite etc. is fine.
Regarding Apache configuration, this site https://ssl-config.mozilla.org/ could give you some examples to configure TLS on your web server correctly.
All info you can provide will help us to help you :wink:
Also, regarding your hosts file, you don't need so much entries and several of them are wrong.
This:
127.0.0.1 .mywebsite.net
127.0.0.1 www.mywebsite.net
127.0.0.1 https://mywebsite.net
127.0.0.1 https://www.mywebsite.net
Should be:
Cheers,
sahsanu
Appreciate it alot! Changed the files now and edited my post with the changes, will look through those other links now, thank you!
I got this from SSL Labs: Assessment failed: Failed to communicate with the secure server.
Your site must be reachable from outside your network, maybe Apache is not listening on port 443, maybe your firewall is blocking it, maybe your router is not forwarding the port... as we don't know your domain we can't test it ourselves.
I'm sorry but I'm leaving in a few minutes, toooooo late here but I'm pretty sure some community buddies could help you.
Cheers,
sahsanu
Its listening on port 80 and 443 also my router with same configuration as before when HTTP did worked, HTTP still works but just being redirected to HTTPS now. Could be the firewall then, any hints on how to check it correctly?
Try using:
Let's Debug found nothing.
Run this to clear your DNS cache then try again:
ipconfig /flushdns
It just tells me its "All OK!", but it's not!
I can access it on localhost machine. If I go in with another computer it now says "Not Found" on HTTP and "Secure connection failed" on HTTPS, no site display on any of them now.
I deleted my redirect in one.com since its already doing a redirect in the config so now I should be able to access HTTP without getting directed to HTTPS but its not working anymore.
Not really sure, its currently setup on a Asus RT AC77U.
Yes, just tell me what tools to try or commands to use and I will.
Hi @rickest
your domain name is required if you want help.
Let's start with PING.
When you PING the name (from any other local system) do you see a local IP or an Internet IP?
