Https certificate not working with www
I just used Mozilla Firefox that I just downloaded for the first time to get a browser with a brand new cache and still, https://www.doctowait.fr is unable to connect
Did you forget to remove the URL redirector record on GanDi?
The www version seems to have a different IP than the others (and have connection refused error)
Thank you
My DNS records look like this
Using my own dns provider I would define
www CNAME doctowait.fr
not the webredir.vip.gandi.net.
And your TTL is 10800 = 3 hours, so you have to wait.
I’ll try that. Thanks!
Sorry I’m not near my laptop so my answer will be short. Right now your cname points to doctowait.fr doctowait.fr and that is not correct. Use only @ or better, instead of using a cname use an A record pointing to your ip.
Note: maybe instead of @ you shoul use a dot to indicate that you want to use your base domain (i suppose that should appear in the help of your dns provider).
Cheers,
Sahsanu
I already have a A record on the first line of my printscreen. Is this what you’re talking about or it’s something else?
– By the way, happy birthday :wink:
Now you have created a wrong CNAME.
doctowait.fr.doctowait.fr
So @sahsanu has the correct idea - use @ instead. Looks like different dns-provider have different requirements.
PS: You can create an A-record with the same ip.
Hi @schtipoun,
No, I'm talking about create an A record for your www subdomain, as @JuergenAuer said, you can have multiple A records, anyway, checking your screenshot I suppose you have created a CNAME for www subdomain like this:
www CNAME 10800 doctowait.fr
But you need to create one like this (pay attention to the dot at the end of doctowait.fr):
www CNAME 10800 doctowait.fr.
So as you are not using a dot at the end, your dns provider is appending the base domain to it so your CNAME record looks like this:
$ dig www.doctowait.fr +short
doctowait.fr.doctowait.fr.
And as I said, that is wrong ;), it should resolve as doctowait.fr. and that is the reason your site is not working now.
Thank you very much :smiley:
Cordialement,
sahsanu
”Feliz cumpleaños, @sahsanu!
It looks all good now :slight_smile:
Now I’ll know for my future projects how to handle all this!
Thanks everyone :pray:t3:
