HTTP-01 error at renewed nginx
The certificate is not renewed, I have no record of any changes being made on the server.
Port 80 are open in server and in firewall.
My domain is:comnetsa.com
I ran this command: certbot renew --dry-run -v
Processing /etc/letsencrypt/renewal/comnetsa.com.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for comnetsa.com
http-01 challenge for comnetsa.com
Challenge failed for domain comnetsa.com
  Domain: comnetsa.com
  Type:   connection
  Detail: During secondary validation: 170.239.59.232: Fetching http://comnetsa.com/.well-known/acme-challenge/C_W3QE8_g-XHJqRzulFbuwKt8nmdENeE0Y8cl6Ow-yk: Timeout during connect (likely firewall problem)
Failed to renew certificate comnetsa.com with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/services.comnetsa.com.conf
Simulating renewal of an existing certificate for services.comnetsa.com
http-01 challenge for services.comnetsa.com
Challenge failed for domain services.comnetsa.com
  Domain: services.comnetsa.com
  Type:   dns
  Detail: DNS problem: NXDOMAIN looking up A for services.comnetsa.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for services.comnetsa.com - check that a DNS record exists for this domain
Failed to renew certificate services.comnetsa.com with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/www.comnetsa.com.conf
Simulating renewal of an existing certificate for www.comnetsa.com
http-01 challenge for www.comnetsa.com
Challenge failed for domain www.comnetsa.com
  Domain: www.comnetsa.com
  Type:   connection
  Detail: During secondary validation: 170.239.59.232: Fetching http://www.comnetsa.com/.well-known/acme-challenge/0-NEUxV1lHjvL2T_CX1umOtM_OWDGOCgauxC6klXarc: Timeout during connect (likely firewall problem)
Failed to renew certificate www.comnetsa.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
  /etc/letsencrypt/live/comnetsa.com/fullchain.pem (failure)
  /etc/letsencrypt/live/services.comnetsa.com/fullchain.pem (failure)
  /etc/letsencrypt/live/www.comnetsa.com/fullchain.pem (failure)
3 renew failure(s), 0 parse failure(s)
My web server is (include version): nginx version: nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.4 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.10.0
It looks like you have geo-blocking that is preventing the secondary validation from succeeding .
