My domain is: china.exed.hec.edu
sudo /usr/local/bin/certbot-auto certonly --apache --dry-run
and
sudo /usr/local/bin/certbot-auto certonly --dry-run --preferred-challenge http-01 -d china.exed.hec.edu --manual
I tried both auto and manual mode. neither of them passed the challenge.
in --manual mode, I created the file and accessed the token URL in my browser successfully.
but the command still returns “challenge failed”.
Create a file containing just this data:
k-YNLtpLBSKXmkbyFCSc06UqXmVkuGSLMsorbLsXRnw.dkN2afar41LWUAkbjM5X25ijoT_Ip-gU_wHE8GtLhw4
http://china.exed.hec.edu/.well-known/acme-challenge/k-YNLtpLBSKXmkbyFCSc06UqXmVkuGSLMsorbLsXRnw
Press Enter to Continue
Waiting for verification…
Challenge failed for domain china.exed.hec.edu
http-01 challenge for china.exed.hec.edu
Domain: china.exed.hec.edu
Detail: The key authorization file from the server did not match
this challenge
“k-YNLtpLBSKXmkbyFCSc06UqXmVkuGSLMsorbLsXRnw.dkN2afar41LWUAkbjM5X25ijoT_Ip-gU_wHE8GtLhw4”
“KXmkbyFCSc06UqXmVkuGSLMsorbLsXRnw.dkN2afar41LWUAkbjM5X25ijoT_Ip-gU_wHE8GtLhw4”To fix these errors, please make sure that your domain name was
Apache/2.2.15 (Unix)
centos 6,
2.6.32-754.23.1.el6.x86_64
NA
no
certbot 1.3.0
