How to use let's encrypt certificate with Azure Virtual Machine
Currently my client site https://kicktone.com/ have free cloud-flare SSL certificate.
But client want to use custom Let’s Encrypt certificate. Because SSL not working with multiple sub-domain.
Site is hosted on Azure hosting and they created Virtual Machine on Azure.
Can any one provide steps for SSL set-up on Azure VM?
Hi @hardik
start with the basics:
Then select a client and start:
But we want to implement on Azure Virtual Machine not in App Service.
This isn't relevant.
If you have root access, it's always the same. Select a client and start.
Checked that domain ( https://check-your-website.server-daten.de/?q=kicktone.com ):
There is already a Letsencrypt certificate:
CRT-Id Issuer not before not after Domain names LE-Duplicate next LE
1372323978 CN=CloudFlare Inc ECC CA-2, O="CloudFlare, Inc.", L=San Francisco, C=US, ST=CA 2019-04-07 22:00:00 2020-04-08 10:00:00 *.kicktone.com, CloudFlare, Inc., kicktone.com, sni.cloudflaressl.com
1365041326 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-05 10:50:08 2019-07-04 10:50:08 kicktone.com, www.kicktone.com
created 2019-04-05. So you have all you need.
The missing thing is the local installation.
Yes, Letsencrypt certificate is there but I am unable to install in Azure. Can you help me?
Thank You!
There is already a certificate installed. Do that again.
PS: I don't see your server, I see only Cloudflare.
So I don't see if it is nginx, Apache or something else.
There is a standard template from Help
